Dont buy comp cam crap!
#103
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
Originally posted by 406 S10 Man
I'm not going to go into it too far, but I have had several comp failures in the last year.
I had the xe284 in my truck last summer. Coming home from work one day it started to bang. I got home and found a couple destroyed lifters and a junk cam. This cam had been installed for over a year when this happened.
The exact same thing happened to the xe268 in my wife's 383 a month later. Middle of the season it just goes to ****. Then one went flat just after/during the breakin. This was a running car, so it started right up and there was no problem during the breakin. I had the shortblock checked out by my machinist and he said there was nothing wrong with it to cause an oiling problem.
I switched to a moly based lube for the next cam breakin and it worked great. Previous to that I had been using the lube that came in the cam box, silly me. I don't know if that was the problem or not, but Comp Cams cost me at least 700 bucks in replacement cams. Plus my truck was down for 3 weeks and my wifes car was down for 6. Working on broken hotrods in the middle of the summer sucks.
#104
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
That is what I think too, but the lube came with the cam! I used some moly from NAPA on the last one and that was successful.
I guess the moral of the story is "Don't us the crap lube that comes with Comp Cams."
#105
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
#106
1 Post
Car: 1986 Z28
Engine: 355
Transmission: th400
i've only read the first half of the post here.
Being a mechanic.. and having two cams wipe out in the same block in the last two years. leads me to belive there's an oiling problem in the block with flow to the lifters.. or lifter bores being screwed up. are the cam lobes that were burnt up on both cams the same lobe?
most times when a hydrualic cam wipes out it's the lifter that goes bad, siezes or otherwise fails. comp has a low failure rate.
#107
Car: 1971 Corvette
Axle/Gears: 3.36
I don't know if you are talking to me, but I had my wife's whole short block checked out by my machinist and he said everything is fine. I had the same thought that you did, but I think it was just a batch of lifters that didn't get heat treated properly. Plus the XE cam ramps are really steep, that has got to be harder on lifters too.
#108
Car: 83Z28 HO
Transmission: G Force 5 speed
I'm no expert, nor am I a certified mechanic, but as I stated way earlier in this post, a Comp XE274 cam was installed in my engine not by me, but the builder and it wiped two lobes on the dyno.
Builder claimed that "they sold me a soft cam, and they know it"....well, maybe they didn't, but they sent a new cam and lifters anyway. All valve train parts used were Comp recommended for the cam.
I've installed a few cams myself on other builds I've done (Crane, Crower) and didn't have any problems whatsoever.
Anyways, the Comp replacement cam was installed, and I drove the car for a year after that, and it wouldn't quit smoking and burning oil. Ended up tearing it down myself to find scored cylinder walls that prevented the oil control rings from doing there job - caused by metal shavings from the 1st Comp cam. Oh but the second cam works and looks fine.
But - I've now spent close to 400 bucks having the cylinders re-honed, buying new rings, all new gaskets, bearings etc...to put it back together.
Figure the odds that I'm buying any more Comp products.
#109
i wasnt going to post to this topic but......
you dont wanna know how many comp cams i have personnaly used, and how many comp cams friends/ family have used, with no problems at all
fwiw
fwiw
#110
Car: 1986 Iroc
fwiw
fwiw
#111
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, LT1
Transmission: TKX, 4L60E
Axle/Gears: 3.42, 3.23
Originally posted by B4Ctom1
yes, straighter cut, phosphating, motive is even worse about that. But if properly set up with a T&D machine tool they wont whine.
http://www.hotrod.com/techarticles/84118/
bought this tool
http://emporium.markwilliams.com/pro...sp?prodid=1669
set up about 200 or so rears at work
never a whine again regardless of manufacturer as long as the gears were new.
bought this tool
But. whatever.
-- Joe
#112
Car: 1999 Dodge Dakota
Engine: 5.2L V8
Transmission: Automatic
Comp Cam Crap
New to this forum, but not new to auto parts and racing. I have worked with Comp Cams for 20 years in my own machine shop and in the race teams that I have worked with. Scooter Brothers is the head of development at Comp Cams and a good friend. I had a customers cam go bad, I call Comp's tech line and told the guy what I think happened (not saying anthing about me and Scooter), he said take the cam to the local warehouse and pick-up a new one. He gave me a RGA number to give to the warehouse, they gave me a new cam. I installed this one and that was 15 years ago. The motor has been in 3 cars since then, no cam problems. Oh, by the way, the problem with the cam was a flat lobe, caused by a bad oil filter by pass.
Anyone that has worked in machine shop for more that 2 years can find what the problem is with any engine. If not, they need to change jobs. Not good business to bad mouth a product line without being able to tell what the cause of a problem was.
Good luck
Mark
Good luck
Mark
#113
Engine: 5.2L V8
Comp Cam Crap
Good luck
Mark
Good luck
Mark
#114
Car: 83Z28 HO
And I'm not referring to any cam failures due to engine problems. I'm simply stating the engine wiped 2 lobes with a Comp cam installed with the recommended springs, guide plates etc...
I've been told by a few machine shops, that sometimes there's a batch that gets out that might not get sufficiently heat treated and will result in a "soft cam" that will munch right up upon startup. Nothing was changed on my engine when the second cam was installed along with lifters. And it's just fine. Guess how I know.
I have it torn down at the moment due to scored cylinders from metal shavings. My guess is it came from the cam lobes.
I'd assume since you work/own a machine shop you looked over that customers engine that wiped that cam real well before you put the new cam in. If 12 years is any indication!
The machine shop that did my engine apparently didn't look over things real well...
But in all fairness, there are other possibiliites like a lifter not rotating in the bore or something. Never had a problem with cams/lifters from other makers.
#115
Engine: 5.2L V8
Comp Cam Crap
Soft cams are about a rare as HEN'S TEETH. The heat treating process is performed in a manner that every cam would be done at the same temp. Two bad in the same batch is just about impossible.
A wiped lobe would, more often that not, come in the form of power in the oil pan as it would not flake off, but grind. These particles would be in the pan, if a magnetic drain plug was used, or caught in the oil filter, assuming the oil filter by-pass was working properly.
As for as bais, I have used every brand of cam, some off the shelf and alot of custom grinds. I have not seen but one cam wiped in 20 years that my machine shop has installed. That one was a Crane and it was a mistake by a former member of my staff that did not break in the cam correct. We run an engine breakin stand, that every engine is run on before it leaves the shop.
Just a side note about the "red stuff" included in the cam, it is just fine if the cam is installed and the engine run within about 4 hours. I use both moly and the red stuff on all cams installed. Moly on the bottom of each lifter and the red stuff on the cam it self. But we do run a drill to prelube EVERY engine. We run the drill for 5 minutes after the oil pressure is above 25 PSI. This process is recommended by ALL cam manufacturer's.
Mark
Mark
#116
Car: 1986 Iroc
Comp Cams called me today and they are replacing my cam and lifters. Didn't ask me any questions so "maybe" they do have the odd one fail.
#117
#118
1 Post
Car: 1992 B4C 1LE
which is why complaining about the #1 company whether it is AFR or Comp or whomever is kind of moot unless they jerk you around. Hello Scat are you listening?
#119
Blackroc86, How long did it take for them to decide to replace your parts, 2 months? Interesting that the guy who used to work for Comp see's this post with 118 replies and over 3000 views and suddenly there is no hassle in getting the bad cam replaced.
And personally, I would not put that thing back in your motor, even if they are free parts. I am sure they did not offer to pay for the machining and repair of engine.
#120
Car: 1986 Iroc
It is winter here now so I didn't get around to sending the cam back right away. I sent it down FedEx ground so I could track it. About a week after they recieved it they called me and went over what happened and said they were sending replacements. The sent the replacements the same day we talked on the phone.
No they didn't offer to do anything other than replace the cam and lifters and I didn't expect them to. Not sure what I am going to do for a cam now. I have some time to think as spring is 4 months away.
ambainb
04-25-2016 09:21 PM
LT1Formula
08-20-2015 09:36 PM
