Who makes the strongest 700r4?
I like my overdrive but im sick of blowing them up! I grenaded two this summer and I am seriously cosidering a th400 or a 350. I really want my overdrive but who can build one to take a beating?
1 Post
Car: 89 IROC-Z
Engine: 383
What about Art Carr trannys? That was who I was planning on going with.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, either AFR or Trick Flow heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
--RPM Racing--
i've heard nothing but good things about pro-built transmissions http://www.pro-built.net
Give them an email/call they are supposedly very good.
Car: 2002 SOM z28
My 700R4 was built by a company in Tallehassee, FL called Fairbanks. It has lasted a few years now with no problems.
Maybe you need to ask why are you blowing up trannys so quickly. With a ZZ4TPI, it may be enough to blow an older style 700R4, but there are people running a lot more TQ then you can make with that combo and they are fine. Are you running nitrous too? If so, is it on a window switch? Running it through the shifts will kill the tranny quick. Do you have a higher stall converter? If so, it would be a great idea to have a cooler on it too.
Around 1989, they went with a 28-vane pump, which helps a lot. Corvette servo and shift kits for better shifts are good upgrades to a stock tranny too. Again, what are you blowing up? The shafts or clutch plates or gears? These are things the company will ask too.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
Two compnaies I have never heard anything bad about: Art Carr (except for price), and Level 10. At the NJ Dragstrips, the overdrive tranny's are usually only built from Level 10 because they last! I've never dealt with Pro-built but I hear very good things about them from people on this board. As long as you get the tranny from a well-known company where they'll give you a free rebuild if your tranny dies in the first few months, then you'll be all set.
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
I like the pro-built trans myself. For $1250 you get their stage 3, then you through in a shift kit an stall, you are looking aorund $1600 for a new bullet proof 700r4.
Unless someone else knows where I can pick up a 700r4 like that for under $1250? If you can let me know.
25th Anniversary Z28
1 Post
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I am running a 92 700R4 behind my ZZ4TPI set up with a 2025 stall and no problems. I also have a 3:23 posi rear so it does spin some.
Eventually I will upgrade to a better built 700R4, Not sure who from, maybe TPI, or maybe I'll check the company in Tallahassee since they are kinda close to Jacksonville.
Good luck and when you go to the 6spd you can drop in 4:10s
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
after going through 3 trannies in as many years i was about to give up on the 700r4. but this place helped me out alot. http://www.bowtieoverdrives.com They know alot and i am pleased with the shift quality of the transmission. you might want to check them out
Eric-86sc
08-24-2015 09:01 PM
700r4, art, builds, carr, hop, make, makes, performance, stongest, strongest, th700r4, trans, transmission, transmissions, year
