Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Adjustable Torque Arm
Old 10-25-2000 | 06:51 PM
IRACE87's Avatar
Car: 1987 IROC-Z
Engine: 383 HSR, AFR 190
I'm trying to find a good torque arm for my car and was thinking about the Random Technology torque arm since it will fit my set up ( T56 with SPD crossmember and Lakewood safety loop)does anyone have bad or good things to say about it????????
1987 IROC w/T56 and a 383 TPI in the works
Old 10-25-2000 | 07:13 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
Don't waste your money on the Random Tech torque arm. It is way overpriced. You can get a T56 retrofit crossmember with integral adjustable torque arm for less than $400 from Steve Spohn. This also includes a driveshaft safety loop built into the crossmember. www.spohn.net It is a superior design and costs less than the Random Tech unit.
1991 Z28 - 350 TPI, T56, Centerforce Dual Friction clutch, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, no cats, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Steve Spohn adjustable torque arm and T56 crossmember
Old 10-25-2000 | 09:21 PM
IRACE87's Avatar
Car: 1987 IROC-Z
The problem is that I found out about Steve Spohn, after I installed the Lakewood safety loop and bought the SPD crossmember . So I need something that will fit with those parts and random torque arm is the only one I found so far.
Old 10-25-2000 | 11:06 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
Steve is right, go with the Spohn torque arm, take a loss on the parts you already have. I just installed the retrofit from Spohn, I am very pleased with the whole setup.
Old 10-26-2000 | 09:13 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
See the message below.
[This message has been edited by ws6transam (edited October 26, 2000).]
Old 10-26-2000 | 09:14 AM
ws6transam's Avatar
There's something to be said about customer loyalty....
Hey, why not see about putting those parts up for sale on the classifieds section of thirdgen as well as camaroZ28.com?? i've had GREAT luck in buying and selling off the boards. In fact, most everything listed below has been purchased either from the boards or mail order through companies who advertise on these boards.
Steve's been very responsive to customer feedback, and that's why he's now getting buried in business. I have all of his stuff on my car and it works well.
If you want to keep what you have, you'll have to choose either the Granatelli piece, the Random Technology piece, and I think there's one from Global West as well as BMR. I suspect that you'll find a Hotchkiss and an Edelbrock piece as well. There's one called the Tracklink out there, too. I forget who is making it: Global west? All of these pieces cost more than Steve's setup, I think.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
Old 10-26-2000 | 06:05 PM
IRACE87's Avatar
Car: 1987 IROC-Z
Steve Torque arm looks good??? now that I drilled my floor pan for the lakewood safety loop
Old 10-27-2000 | 07:16 AM
ws6transam's Avatar
If you want to see my install notes for the Spohn stuff, check out: Dan's Torque Arm installation notes
There's some good pictures of the actual hardware. This was an early design and Steve has taken our feedback and updated his designs to make them better.
[This message has been edited by ws6transam (edited October 27, 2000).]
Old 10-27-2000 | 07:56 PM
IRACE87's Avatar
Car: 1987 IROC-Z
Maybe I can get the T56 retrofit kit without the safety loop so I can keep the one I already have????
Old 10-29-2000 | 08:11 AM
SteveSpohn's Avatar
You can get it without the loop, just specify that when you order.
Steve
Spohn Performance: F-Body Chassis/Suspension Specialists
Hotrodboba400
12-10-2019 07:07 PM
J-money
01-04-2019 09:45 AM
Nick McCardle
09-10-2015 08:36 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Adjustable Torque Arm
