Aftermarket swaybars - How much of an improvement over stock??
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
How much of an improvement over stock can be expected when installing aftermarket swaybars? What sizes will offer the greatest benifits?
Mark
Mark
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Depends on what you have now.Mine came with the big factory bars and all the manufacturers tell me that I wouldn't gain anything by going to aftermarket.If you have the F41 suspension (1LE even better), don't bother changing them.
-Rich-
-Rich-
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Yeah, my 86 Sports Coupe had the F41 swaybar package and we changed it to the Z28 pack. Minimal differences. You would notice it on a wide open race course but not much in daily driving.
Aftermarket swaybars are meant for cars with no swaybars, or ones that are damaged.
The largest stock sway bars are those used in the FE2 cars. Stock suspensions start with FE1 at the base end, F41 in the middle, and FE2 at the top. From what I've seen the F41 and FE2 share the same rear sway bar but the front is larger on the FE2 cars. The 1LE cars and late WS6 cars have the largest front sway bars at 36mm. They run as low as $5 each in the junkyards if you can score a deal. Aftermarket bars may be a little stiffer but they'll be heavier also. Stick with stock pieces for the best of everything.
Drew
predatorman@hotmail.com
83 Camaro 5.0L *1995-98*
87 Iroc 5.7L
91 Formula 5.7L 14.3@98mph
91 RS Convertible 5.0L
91 Firebird 3.1L 17.00@82mph *Gtech*
92 S10 2.8L
98 Grand Am GT 3100
Parts for sale
Drew
87 Iroc 5.7L
92 S10 2.8L
98 Grand Am GT 3100
Parts for sale
Street Lethal
04-30-2019 12:14 PM
