Canfield Heads dyno numbers???
Car: 1984 Z28
Engine: 350ci
Axle/Gears: 3.73 12 bolt
I've used the search and found plenty of topics for canfield head's flow #s and prices, but i could not find anything that listed a combo using these heads along with any dyno or dragstrip numbers. Flow numbers are all well and good, but its performance that is what is really important. So, anyone using these heads?? What kinda build-up and #s you got?? ANY help would be appreciated, as i came up blank on the search.
Thanx.
DG
Thanx.
DG
You are correct in sayin that flow #'s don't mean jack w/o being proven on a setup. I know this won't comfort you any, but my friend is building 383 stroker motor, and he's using a set of Canfield 190's. Dunno how it's gonna do, just letting you know that Canfield's do get used. He also kinda wondered the same thing you are. It seems noone is running these heads, yet they seem to be pretty good. Guess we'll see, sorry I can't do any more for you man.
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Re: Canfield Heads dyno numbers???
I know this doesn't help too much, but I have some pics of my Canfield's I took the other day after I just got done porting them. These are some older ones.... you can see the date stamp on them 07/97. I just picked them up from the machine shop today.... they had 2.100 intake valves in them, but the seats were a little too small for those valves, so I had the seats cut correctly for them. Pics are here LINK
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
From what I understand Canfields share a similar port design to AFRs but dont quote me on that. AFR used to be Brownfield Heads which Canfields are based off of.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I think Traviz ran some canfields for a while, maybe try Pm'ing him.
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
i remember when canfields were the head people use to run till afr came along in the rustang world..... they used to be some stangs around here that would flat out scoot and they had canfield.....
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i did run canfields. great heads. ran 13.1's on my 350 with stealthram and shortys. and the same with my horribly tuned 383.
I am running a set on my 406 they are the 215cc, 2.05, 1.6 72 combustions chambers with about a 555 lift solid cam with around 255 duration i would need to get the cam card if you want the specifics its an off the page xtreme energy. victor junior 750 holley 1-5/8 shortys with 3.0 duals mechanical fan power steering pretty much in street trim. With drag radials run an 11.7 on and ill running motor on 89 octane. 350turbo and about a 3800 stall. Not saying thats great but its not bad. freshen up the motor now and fixed a few things will be going racing soon shooting for under and 11.5 now! Don't know what i pushing for hp guessing 525 range.
LT1Formula
20
11-14-2015 12:02 AM
