What distributor should I use with a Weiand Tunnel Ram that won't clear GM HEI?
I guess it would have to be something short with an external coil?? I've never used anything except hei distributors, HELP!
1987 Formula 350, headman hedders, Accel supercoil, cap, rotor.
MAF screens removed. 160 degree stat and manual fan switch.
Best ET: 14.745@91.317mph-Stock
Best ET: 14.418@95.51 mph-Modded
Ridiculed Founder of the Traction Impaired Crew
I am quite fond of Mallory Unilite ignitions with vacuum advance. Pretty reasonably priced and totally electronic. Need a matching coil and a bit of wiring and new plug wires. Use plug wires with a spiral core and very low resistance per foot. MSD makes the best ones, think they are called Super Conductor, or something like that. Top quality equipment.
1 Post
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
The low profile MSD {part# MSD-84697} clears tunnel rams and blowers.It uses the HEI style plug wires and external coil.It also has a slip collar that is adjustable for use with standard,tall,or decked blocks.For right at $145.00 bucks its a nice peice.
Superman
Rev'n to Seven
Superman
Rev'n to Seven
Crank Trigger distributors are designed for racing engines that use a crankshaft triggered ignition Crank Trigger distributors are designed for racing engines that use a crankshaft triggered ignition
1 Post
Car: 1989 Camaro
Engine: 406
A crank trigger ignition is the most accurate means of ignition that you could have.It uses four magnets embeded in a aluminum wheel that bolts to your balancer.As the crank rotates the magnets pass a non magnetic pickup and triggers the ignition.It uses the crank to activate ignition rather than the cam,it is far more accurate becuase false triggering of the ignition is eliminated.
Superman
Rev'n to Seven
Superman
Rev'n to Seven
Hotrodboba400
12-10-2019 07:07 PM
Stangski09
11-14-2015 01:27 PM
86CamaroDan
09-29-2015 10:08 PM
