MSD Ignition parts
Car: 87 Camaro Z28
Engine: LG4, CCC
MSD Ignition parts
I'm looking to upgrade my ignition system on my 87 Z28. It has stock igntion components thus far. I was looking around Summit Racing's site, and specifically at the MSD Ignition stuff, as they were suggested by a friend. I'm pretty new to this stuff, so this is the shopping list I came up with, I just wanted to run it buy you guys, since you all know what you're talking about, and I'm sure some of you are using MSD Ignition components. So how about some feedback/suggestions? As far as I can tell, these will all work together, but maybe there's something I didn't catch.
Is there any important differences between the (I'm not sure of the proper names for this, but...) male and female distriputor cap layouts? I mean where the ignition cables attach into recessed cylinders, and where they stick up, exposing the (copper?) tips? Is one better/worse?
Also, is the Blaster GM Coil the correct part to get to replace my distributor coil with? That wasn't particulalrly clear to me.
Last thing, on the ignition wires, the site says its only good for engines up to '74. But the guy I talked to at Summit said they are the ones I should use. Is he wrong/full of crap? I didn't see anything on there that was appropriate with regards to engine size and year...
Sorry about the length and lack of interest of this post, but I don't want to spend my money without knowing more about what I'm buying.
Thanks in advance.
http://store.summitracing.com/partdetail.asp?part=7437
ignition wires
http://store.summitracing.com/partdetail.asp?part=9030
distributor coil
http://store.summitracing.com/partdetail.asp?part=9122
rotor
http://store.summitracing.com/partdetail.asp?part=24740
distributor coil
Thanks in advance.
ignition wires
distributor coil
rotor
distributor coil
i like the caps with exposed tips. if you're engine is stock i doubt you see much of a gain unless you need a tune up anyway. i like the wires you cut to length. msd makes good stuff, you won't have a problem with it.
Car: 1985 Trans Am
That is the correct coil, however, those are the incorrect cap, rotor, and wires. you need the cap rotor and wires with HEI style terminals. They sell them specifically for the 87 and up external coil distruibutors, look for that in the product discription.
Car: 1985 Trans Am
external coil type distributor cap:
http://store.summitracing.com/partde...art=MSD%2D8426
external coil style rotor
http://store.summitracing.com/partde...art=MSD%2D8427
cut to fit wires:
http://store.summitracing.com/partde...rt=MSD%2D31189
pre cut for remote mount coil:
http://store.summitracing.com/partde...rt=MSD%2D31839
cut to fit wires:
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Originally posted by Frank_Blotto
alright, thanks man
alright, thanks man
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Originally posted by CaptPicardsZ28
I buy the universal MSD Super conductor 8.5mm so I can cut to fit.
Car: '94 Corvette
Yea, you definitely need a little patience in sizing, cutting, and crimping the wires yourself.
You also want to test each completed wire with an ohms tester.
I found myself having to re-crimp a wire that I thought was perfect cause it had excess resistance. So you will want to test them all.
BTW: 'CaptPicardsZ28' I meet Pat Stewart back in '87-'88?, and got his autograph - even got a hand shake for him. Coolest ST cast member ever, then again I meet W. Konig in '90, and he is cool as he** also - gave me two autographs!!! Havn't been to a Star/Spring Con in 10 years
Ron
Ron
LT1Formula
20
11-14-2015 12:02 AM
tartagliaz28
08-15-2015 10:59 AM
