info on this intake please
sry if this should not have been posted in the section.
does anyone know of the holley contender intake manifold??
my car came with this intake and i cant find info on the holley site. i want to know if it is anygood or should i look into a new one. also there must have been a hole or crack in it as some point because there is a metal plate with a screw one each side and some black glue/sealer on buttom to prevent leaking i guess (pic below...i drew in what rest is like, thats the best pic i have that shows it sry) anyway have this done will it effect the performance of the intake?
i managed to find a pic of my intake but still no info on it..anyway in pic it seems to have that plate there also so i am thinking it could be normal (if so y)...anyone ideas?? also still trying to find info/performace of this intake..anyone??
i added pic of new look..for example of plate again and of the intake
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i dont think thats the EGR block off plate becuz my edelbrock has the same plate over the same spot and thats for a heat choke. the egr position would be right around where numbers 6 and 8 runners are.
Car: 05' GTO
Engine: 6.0L
Transmission: A4
heres an edelbrock with the egr mounting holes for the egr, im sure every sbc manifold is like this but i found this pic first.
Car: projects.......
The hole can be used for either an EGR or for a choke stove. - The holley Contender is a good intake. Thre are two models, same as Performer and Performer RPM, its the difference in hieght and power band. If yours is spreadbore and squarebore patterned, then its basically the same as a Performer, just w/ Holley's designing. If its square bore only, then its basically a Performer RPM. - Look up a Holley Street Dominator intake. Same intake, just a new name.
later, justin...
later, justin...
Car: 05' GTO
Engine: 6.0L
Transmission: A4
yeah i looked up the Street Dominator and it has the holes ONLY for the heat choke. it doesnt provide the holes for the EGR. if you look at any other intake with those same holes its not for the EGR, it will not bolt up.
"510-300-38
Idle-4800 rpm, Dual Plane, Square & Spreadbore Flange
Works equally well on the street or at the track thanks to its dual plane design that enhances fuel distribution and its raised plenum divider that improves torque. Accepts both spread bore type and Holley flange carbs. Features late model alternator and A/C bracket mounting provisions. No EGR.
Features:
Idle-5500 RPM power band.
Low rise/dual plane design.
No EGR provision.
Spread bore and square bore carburetor mounting flanges." that was right from Jegs in the discriptions.
i looked at abunch of other holley intakes and edelbrocks and all the holes for the Heatchoke are just for the heat choke, they say no provisions for the egr enless stated. so that plate on your intake is the same plate i have on my intake and its just for the heat choke.
"510-300-38
Features:
No EGR provision.
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
I have one of these for sale if anyone is interested..
Hotrodboba400
12-10-2019 07:07 PM
86CamaroDan
09-29-2015 10:08 PM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
