255 or 265/50/16
1 Post
Car: 96 Formula/82 T/A
Engine: LT1/350 TPI
Transmission: T56/TH350
255 or 265/50/16
ok. i have 16X8 Formula Rims on my 82 T/A. but i need new tires. i want to put 245/50/16 on the front. but i want to go wide on the rear but how wide can i go on these rims. is 265 ok. or should i go with 255. thanks
RED82TA5.7L
1982 T/A
350 CFI(TPI soon)
"Not Stock"
Mods and Info
T/A / GTA / Firebird
TransAmGTA.com
[This message has been edited by RED82TA5.7L (edited November 10, 2001).]
RED82TA5.7L
1982 T/A
350 CFI(TPI soon)
"Not Stock"
Mods and Info
TransAmGTA.com
1 Post
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
265's will rub, 255's won't. I have 16x8 255/50/16's and they work great. I had 265's on my 15x7's and they rubbed.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
<font face="Verdana, Arial" size="2">CobraKiller1989:
When it comes to blow jobs, as long as ur not but a$$ ugly and you have a pu$$y ...if you offer, i will let u suck me off</font>
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Keep in mind as you increase width, the height increases w/it, slowing down your speedo.
245/50 = 25.65" height, 9.1" width*
255/50 = 26.04" height, 9.7" width
265/50 = 26.43" height, 9.9" width
255/50's made my Camaro's speedo off by 5mph around 50 and have had no rubbing problems.
265/45 = 25.39", you could go with this size for widest on an 8" wide rim w/the least speedo accuracy problams. If it was possible to mount (?) 275/45 is an exact height match to the 245/50's.
You can check for yourself using this nifty webpage
http://elvis.rowan.edu/~kristovi/java/Tire.html
*Tread witdths are based Kumho VictorRacer tire specs
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
[This message has been edited by deadbird (edited November 12, 2001).]
- my Formula Homepage
- Collision P/Ns & Diagrams (80ish% complete)
1 Post
Engine: LT1/350 TPI
well. my speedo is off by 15. when im going 70 it says 85. so if it slows the speedo it will help. so ill go with 255. thanks for your help
RED82TA5.7L
1982 T/A
350 CFI(TPI soon)
"Not Stock"
Mods and Info
TransAmGTA.com
RED82TA5.7L
1982 T/A
350 CFI(TPI soon)
"Not Stock"
Mods and Info
TransAmGTA.com
1 Post
Engine: LT1/350 TPI
255 is the distance in MM from one side of the tire to the other(including sidewall) and the 50 is the percentage(i think) that is on the sidewall. so going to 255 will change my speedo
RED82TA5.7L
1982 T/A
350 CFI(TPI soon)
"Not Stock"
Mods and Info
TransAmGTA.com
RED82TA5.7L
1982 T/A
350 CFI(TPI soon)
"Not Stock"
Mods and Info
TransAmGTA.com
ambainb
04-25-2016 09:21 PM
