Accel Super Coil =Good part
I installed the Accel super coil a few days ago. I didn't expect any SOTP gains, but for 50 bucks, I figured why not?.
I put it on in about 25 mins. Would've taken 5 but messin with the rivets on the bracket is a pain. I have MUCH better top end(2000 and up)! I was definitely impressed. I am expecting an increase in gas mileage too. I will post those results as soon as I get them calculated.
I would recommend this to anyone. For the money,it can't be beat!
89 RS parts car
Daily driver 91 RS auto LO3 70k, 14x3 K&N Open element, cat-back delete, Richmond 3.42's, Zexel Torsion posi, Accel remote mount Super Coil.
Coming soon: 470HP 383, Hooker SC/LT headers, true dual Loudmouth exhaust, gutted cats.
89 RS parts car
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Right on Ryan!
This is an upgrade I'm thinking of too. But I have an integrated coil so it is a tad different.
Keep us up to date as to whether you start going through caps and rotors. I've heard this sometimes happens.
Car: 1992 Z28 1LE
I agree.. I remember putting one on my '76 Datsun, and I definately noticed a bit more on the top end... as sad as it may sound, before the upgrade, I would start decelerating from 60mph on a slight incline with my pedal floored. But after the coil went it, I was actually able to keep it at 60mph.
I know a guy that has the coil-in-cap type and he is very happy with his too.
I'm thinking about getting a performance cap and rotor, but I don't know if they are really worth it.
Anyone have experience with this?
89 RS parts car
89 RS parts car
Car: 1992 Z28 1LE
I remember that replacing the cap&rotor (ACCEL) was the first thing I ever did to my car when I knew NOTHING about cars. I did notice that the throttle response was a little crispier.. but then again, the previous cap and rotor was quite worn out.
Car: '86 TransAm WS6
Transmission: Custom TH700R4
I have the HEI SuperCoil (the one mounted in the distributor) and I noticed an immmediate improvement. A reccomended mod, although accessing the HEI on a TPI motor is a little difficult.
Good bang for the buck.
1 Post
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
i recently replaced my cap and rotor with a performance one and noticed a difference too. i agree with age though, it could've just been that the other one was worn out badly.
I have the Accel super coil and i noticed a little bit of a difference higher up in the RPM`s i bought mine off of someone on the boards here.
87 IROC-z 305 TPI
Borg Warner T-5 fresh rebuild
10-bolt 3.73 Richmond gears rebuilt GM posi,
formerly BW 9-bolt w/3.45 gears(broke it)
Ported Plenum and Runners Homemade AFPR
ACCEL 8.8 wires, High output coil,and cap & rotor
Bosch platinum + 4 plugs
Ram Air w/ K&N filters,
MAF sensor screens removed, TB coolant bypass
Polyurethane tranny and torque arm mounts
Gutted Cat, Dynomax catback w/custom tips
K&N oil filter,Mobil 1 synth,Factory Oil Cooler, Futura GLS Super Sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
87 IROC-z 305 TPI
This was one of the first things I did along with new Accel plugs, Accel 8mm wires and a Hypertech cap and rotor. A noticeable difference! I used the factory bracket by dremeling off the rivets and replacing with SS screws. Pix on my website.
87 TA, 305 TPI, Custom CAI, K&N, ACCEL 8mm wires,ACCEL Super-coil, ACCEL Plugs, JET TPI Airfoil, Cherry Bomb Muffler
"35 yr old helo pilot
with a cool new toy my 17 yr old son wants" The Phoenix Project..click to see my project car
Trans Am stuff and GIRLS, GIRLS, GIRLS!!!!!
