TPI on Vortec Heads
TPI on Vortec Heads
I am planning on using Vortech Heads on a
L98 shortblock with the original TPI.
I am looking to purchase the new Vortec baseplate from Scoggins/Dickey. Anyone using this combo or see any problems?
thanks,
thanks,
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Those aren't new, and they're junk (unless another redrilled Vortec is out). The ports don't line up correctly, and the angle of the redrilled holes cuts down on the thread depth greatly, get ready for stripped intake bolts...
The TPI Vortec intake is the only way to go, I haven't seen any performance numbers other than the ones on scoggin dickeys site though.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I don't even know why they came out with re-drilled Vortec heads. Like Ray said, the ports don't line up. I don't see a way to drill them so that the ports would line up in the first place. If you get the SD base manifold, you should be set.
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust, Dynomax Bullet Mufflers, T&R Motorsports custom air intake, Bald tires
Joshua Johnston
1991 Z-28
The redrilled vortec heads first showed up on the dirt tracks and were used with single plane intakes that had raised intake ports. This is how they got around the problem of having the ports not sealing and as far as the bolt holes they just had to be real careful and not strip them out.
Car: 1991 Z-28
I didn't think of that. These were pretty popular with circle track, and stock class racing before the general public realized the power potential. Huh, you learn something new everyday.
Joshua Johnston
1991 Z-28
Joshua Johnston
1991 Z-28
84z96L31vortec
08-20-2017 12:16 AM
L98GTA87
08-11-2015 06:55 PM
84z96L31vortec
08-10-2015 08:27 PM
