Classis Ind. Brake Custom Brake Lines
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
I bought the complete set for my 82 Z and they fit perfectly. All pre-bent and I had no problems putting them in and for the final touch I put on Goodridge Line and those are top notch too.
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Are they stainless steel by chance?How much was it..and what all was included?All the hard lines for the car?Starting to gather parts for a frame up resto mod soon.TIA
Car: 1982 Z-28
Engine: 383
Onebad - you can get stainless, I went with original since the car never sees bad weather. The prices were not bad at all. I got all the lines, except for the rear ones (I just changed those when I did a rear swap). I bought the front to rear, $50 and then two front ones - around $80 (I forget the exact price, I don't have the book with me but I'll get it for you soon). Very good quality and all matched up perfectly.
The most expensive pieces were the Goodridge lines. They were $100.
