hood louvers aftermarket?
Car: 1985 Z28
Axle/Gears: 3.90 10 bolt eaton posi
Are there any aftermarket hood louvers out there. If so, are they good, or made of cheap plastic.
Thanks,
Rob
Thanks,
Rob
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
If you want a good way to look at different models, and have full color photos with descriptions. Just goto http://www.classicindustries.com
And get their catalog, u can either buy it or DL it. Either way its worth your time to take a look
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
I ordered mine from gmpartsdirect.com (They were OEM, but not too expensive through them)
GM PART # 14081351 (left hand side)
GM PART # 14081352 (right hand side)
And also:
GM PART # 14081351 (slicing nuts, so you can attach the louvers)
I wish I had the last p/n when I ordered my OEM replacements. I had to use 7mm nuts, and force them onto the blank plastic pegs on the new louvers. Broke a few of them in the process. : (
Hope I helped you out, at least helped you find a better price than you can through classicindustries. com
(edit: this is for the 85+ black hood louvers, NOT the 90+ hood blisters)
And also:
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Hotrodboba400
12-10-2019 07:07 PM
