Crane camshaft identification
Car: 1988 IROC-Z
Engine: 383 HSR
Transmission: 4 speed Automatic
Axle/Gears: 4:10
I want to buy a camshaft from a guy that says that it is a crane compucam 2032. He says that he took it off a crate engine.
My concern is that the cam does not have a number cast in in, but instead it says powermax 2032 that is written by hand with one of those tools to write on metal.
My question is: Do this cams come with this kind of writtings from the factory, or there has to be a number cast in it?
Thanks a lot for yur help.
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
Crane cam ID marking
The one I bought is marked with an electric pencil (vibro-peen) for the numbering. It's all by hand, not a fancy engraving machine or process. I've seen some other cams this way as well.
And of course, the Crane Powermax is the old Compucam line ( a rose by any other name is...)
I'll liik for a pic tonight if it would re-assure you. if in dought, have the cam measured for true events timing..
Car: 1988 IROC-Z
Engine: 383 HSR
Axle/Gears: 4:10
Just wanted to let you know that I took the cam to a shop to have it measured, and in fact, it is a crane 2032. I gess that that's the way they mark their cams.
Thanks Kevin
Thanks Kevin
Glad you mesured it. Relieves all
questions. As it turns out, I've got pics from all ends and views of the cams I laid out, but the marked end glared with the flash. Cam is now installed, so not practical to take a new pic!
Hotrodboba400
12-10-2019 07:07 PM
88SS6SPEED
11-11-2015 07:05 AM
GTAman
09-26-2015 02:01 PM
