Tire Sizes. 255/50/16's or 245's?
1 Post
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I have 15's on the car right now but I am putting 16x8's on real soon. I had 265/50's before and on the front they rubbed very slightly if I turned the wheel all the way. Now if I go with 255's with these 16x8's will they still rub? Remind u that the 265's barley rubbed the inside of the wheel well. Is there anyone out there with 255's with 16x8's that can tell me if when u turn ur wheel all the way do they rub? Thanks a lot guys.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
I am having a set of 255x50 16's mounted on 16x8 GTA rims on Tuesday. Ive been running 245x50's, Ill let you know how they fit once they are on. Good I hope!!! From what I have heard though I dont think it will be a problem.
89 Formula, 305TPI,TTops
Car: 1989 IROC-Z
Engine: 1992 TPI 350
Transmission: 1989 T5
Axle/Gears: 1992 10 Bolt Rear w/ 3.42 gearing
depends on the offset of the 16x8 that you are going to put on the car... to help you visualize the difference between 265's and 255's... 10mm is about 3/4 of an inch....
you shouldn't have any problems at all
[This message has been edited by prockbp (edited September 09, 2001).]
I have 16" IROC rims with 255/50/16 tires and after an alignment they didn't rub the wheeelwell. So I know with proper backspacing and alignment they should work.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
'86 IROC 5-speed
305 LG4
'95 3.23 rearend
1 Post
Engine: 3.8
Axle/Gears: Dana 60
Hey DROPZTOP89,
Did u get ur GTA rims from Classic Industries? Mine are the offset rims from classic industries.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Car: 92 Camaro RS
Transmission: T5 manual
I'm running 255/50-16 autocross tires on factory 92 Z28 wheels. I have no problem with rubbing in the front, but I do have some rubbing with the rears. This may not be a problem with street tires/street driving. In addition, I believe the rear suspension bushing need to be replaced as well.
Bill Rockhold
92 Camaro RS, 305 TBI M5 F41
SCCA Solo2
Bill Rockhold
SCCA Solo2
1 Post
Engine: 3.8
Axle/Gears: Dana 60
What about profile? Anyone running a 45 profile? Do u have problems with ur car rubbing the ground? Mine has the 91 GFX so it is 4-5 inches from the ground. Think I would have a problem if I was to go with the 45 profile?
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
The lower profile 45vs50 is not going to make you scrape...I wouldnt think. It will lower the gearing of your car so it may pull slightly better 60' and Quarter times. I would think the only downside would be gas mileage and possibly traction off the line. (if you are already having one it will get slightly worse) Anyone done this because Im speaking only from theory?...I'd be interested to see if it works.
Hope that helps
Hope that helps
Believe it or not my GTA rims were added to the car at the dealership were it was originally bought new. My dad bought it new back in 89, he didnt know the difference between the Formula and GTA rims. He did say he picked the car car out because it stood out the most. Had to be the rims. I was thinking about ordering two GTA front rims from classic to add to put on the rears just to add a little more aggressive look. But I need charcoal spokes.
1 Post
Engine: 3.8
Axle/Gears: Dana 60
No, I am talking about 255/50's I know they don't come in 45's but I think that I am gonna go with the 245/45's all around.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
1 Post
Engine: 3.8
Axle/Gears: Dana 60
Kumho makes a 245/45/WR16
Check tirerack.com it is lists all the tires for a certain size and rating.
http://www.tirerack.com
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
I finally got the 255x50 16s mounted (not until Saturday) and they fit great. Car has a more aggressive look, and the Khumos seem to handle really good. Im happy, and the Bird is too!
89 Formula, 305TPI,TTops WS6, GTA wheels, Flo Pro muffler, K&N Air Filter, New paint, original GM white, Stewart water pump, 180* Robert Shaw Thermo, SLP Air Booster, Family owned since it was new!
You guys must not have seen my ad...I have Goodyear GSC 245/45/ZR16's for $279.00 a set. That is a set of 4...they are brand new, not blems. I took advantage of a mistake in the Goodyear catalog and got a truckload of them. Email me at CarNDrvr@aol.com.
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
Eric, long time no chat.
I have heard from people that have 255s all around, 245s all around, and a combination of both.
I remember talking to a guy that has an 86 IROC that has 255/50ZR16 SZ50s all around, and he said that they have never rubbed. But then again, somebody else I have talked to over said that they rub like CRAZY. But, I think it is hard to say..everyone has different stories about it.
Just to give you an idea about how different it is, a friend of mine had a 91 RS too, and his front 245s rubbed like a b*tch. I think that it comes down to the tire itself. You know how some tires have larger footprints than others that are the same size? Well, I think it has to do with that maybe? I dunno.
I did the middle of the road thing...255s in back and 245 in the front.
-Brian
1991 Camaro RS - ultra blue metallic, t-tops
GMPP 350 HO crate engine - 454 TBI, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
z28boy.cz28.com
Central New York F-Body Association
z28boy@twcny.rr.com AIM - "Z28 Boy"
1998 Pontiac Grand Prix GT - 2 door, black
-Brian
z28boy.cz28.com
1 Post
Engine: 3.8
Axle/Gears: Dana 60
Yeah where in the hell have u been?
Well Brian, I thought about doing what u did a long time ago but then how am I suppose to rotate them? So I think I am gonna just go with the Kumho 245/45/WR16's.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I have 245-45-16's on stock 92 16" wheels.
The car was pretty low, before I put them on, and after, I had to cut the springs a little more to get it to look right, since the gap at the fender is bigger. Looks good now, but car needs to be pretty low with 45 series or it just doesn't look right to me. Mine are Falken GRB's , about $110 apiece at Wheel Works.Best handling tires I've had, and not nearly as scary in the rain as some.
1992 RS,5 Speed,T-Tops,Eibach Springs(cut), KYB's, Lakewood Trailing Arms and Adjustable Panhard Bar,Posi Disc Rear,3.73 Gears,Summit Rearend Support Cover,
Del-A-Lum Bushings,300 HP Crate Motor,Crane Comp-U-Cam,Edelbrock TBI Intake, Turbo City Ported Throttle Body and Adjustable Fuel Pressure Regulator,Open Element
Air Cleaner, Ground Control Strut Tower Brace and Caster/Camber Adjusters,SLP 1-5/8" Headers,Flowmaster 3" American Thunder Exhaust,3" Cat,Centerforce Dual
Friction Clutch,Hayes Billet Flywheel,B&M Power Steering Cooler,Big Thumpin' Stereo.
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
Stock 86 16x8 wheels and 245/50/15 Goodyear GT+4 all around. They rub on the front at full lock.
Must be that 1/8" of road tar buildup on the fenderliners!
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
cars that came with different wheels had different stops in the steering box depending on the wheels that it came with. A car that came with 15’s will rub in the front at full lock with anything wider then a 215, on a lowered car with a 235 60 15 or a 245 50 15 (not sure about the 255) you can stop the rubbing by running about ¼” spacers.
Mark
'87 Formula 350
’83 Crossfire TA
'97 WS6 TA (for sale)
Mark
'87 Formula 350
’83 Crossfire TA
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
I just got those tires CrnDrv was selling 4 for $279 245/45/16s Goodyear GS-C. They're very nice looking, sidewalls are verticle(straight) no curved bulge look. They are however noticably shorter I'd say close to 3/4". It's not a bad thing, but creates a larger fender gap. I also can imagine these tires handling better than 245/50 series tires. I'm already quite impressed with them after only 1 day and would probably buy extras to save if I wasn't planning on 17" wheels.
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I have 255/50*16 front+rear on org. GTA rims.I having problem with rubbing in the front....
/N.
GTA -89:383, 4-bolt,Free flow muffler,dual 3" HF cats, Edelbrock headers, Canfield heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods,looking for a SR ...
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
/N.
Car: 2004 GTO
My 1989 Formula 350 has the stock rims and 255/50/16 BFG ZR's. They rub the inner fender liner at full lock, but otherwise no probs.
It also depends on the tire brand. My dunlops 255/50/zr16 rub in the front but I think it was firestone firehawks that didn't (can't remember for sure). Also ifyour car came with 16's then your steering stops are set differently also.
1 Post
Engine: 3.8
Axle/Gears: Dana 60
How would I go and change my steering setup?
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Car: 92 Camaro RS
The best Steering Box to have is marked "XH"
on the cover.This is the box that came on 91-92 Z-28's and RS's that came with 16"x8" Wheels.Stops are correct for big tires and
I think ratio is 12:1.
-Rich-
-Rich-
1 Post
Engine: 3.8
Axle/Gears: Dana 60
Thanks, I will check that out if the tires rub bad.
And Beast5spdGTA, do u have a pic of ur ride with those tires on it now?
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
I have BFG ZR4 245/50/R16's on the front of my 89 Rs and they rub considerablly at full turn and they are monted on 16x8 blk GTA wheel. The GTA wheels may have a litte diffrent of an offset than the stock 16x8 wheels. JMO
Car: 91 RS
Mine has the black center GTA wheels from Classic Ind. I ordered all front offsets and have no problems running 255 50 16's. I have ran Comp T/A ZR's and now have Falken Ziex's on there. The Ziex's handle better!
91 RS 5.0 TBI....Edel. TES headers .. 3" exhaust ..... 5spd 3.08
1 Post
Engine: 3.8
Axle/Gears: Dana 60
Alright guys, I think I am gonna go with 255/50WR16 Kumho ECSTA Supra 712's. Thanks a lot for ur help.
BTW: I will post pictures this week on this thread.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
[This message has been edited by 91Bird305 (edited September 29, 2001).]
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
