What are you guys engine running on??
#151
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: What are you guys engine running on??
I have always used Castrol GTX but will probably change as I have noticed more sludge than normal on my vehicles.
When I worked for a tree company they swapped to Royal Purple on all trucks and experienced much more oil burning compared to the dino oils except on trucks that started running Royal Purple on a very low mileage. They swapped back to dino oil in the higher mileage trucks.
For the filters after you understand what they say you can see that fram is for the most part a very poor choice. I have seen a Fram filter balloon up. Wix and Napa filters worked fine on the same engine.
#153
Car: 1988 Black GTA
It is a digital dash. So it goes to 60 and then off the chart so to speak.. It seems to be good.
I saw in some old maintenance records that he (my dad) requested that Slick 50 be put into into it. I kinda remember him having that done.
That being said is it ok to put synthetic oil in it?
#154
1 Post
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
#160
Hey guys I use 10w-30 Valvoline most of the time it's what all the shops in my town use basicly.
I've had good experience with Quaker (4x changes) an the car ran alot better an seemed not to get as hot... also my car didn't die out when I went 100+ mph... so im not sure if it's bad but it did take going over 100mph..
However the worst oil by far HAS to be Penzoil it is the shittiest oil by far i'd take walmart oil over it. I've changed numerous cars that ran Penzoil an everyone you can see the deposits flow out like it's never been changed before gunky!!
Also from person experiance I would say Synthetic oil made my Saturn leak so bad I had to replace the engine. As soon as I started the car after changing the oil 10 sec later it wouldn't stop leaking.
#161
Car: 1983 Z28
Engine: Forged 355
This right here I use for my flat tappets.
http://www.ruralking.com/automotive/...al-bucket.html
#162
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
we just got a rural king in my area, haven't been yet been meaning to get there, word is they got oil CHEAP
#163
Transmission: 5spd
p.s. everyone stop hating on FRAM nothing wrong with a FRAM filter unless your building a race engine
theshackle
03-05-2017 06:37 PM
