Best heads for under $1100
1 Post
My mods are listed below. Barring any intake compatability problems (i.e. Vortec heads on TPI manifold), what are some really good heads I can put on my car? Trick Flow? Vortec? Dart? Keep in mind that Vortecs are really cheap and I'm on a budget. I know that some heads might outflow others but what is going to be the best bang for the buck?
"Though I cruise through the valley of Rice I shall fear no turbo, for torque art with me."
1985 IROC-Z w/T-tops, 305 out and 350 L98 TPI engine in, Hooker Super Comp Headers, 3" Hooker Super Comp Cat-Back, 3" CatCo Cat, Rebuilt TH700R4 with Shift kit, 3.73 Richmond gears, Auburn differential, Accell SuperCoil, Accell 8.8 racing wires, BBK AFPR, Homemade Ram-Air (thanks to Andris Skulte), MAF screens removed, Dropped A/C, TB coolant bypass, Hurst Dual-Gate Shifter, Air Foil, K&N filters, Holley performance fuel pump, Spohn Subframe Connectors, Re-located Spohn Lower Control arms, and more to come.
No question in my mind. The 195 Canfields.
www.canfieldheads.com
Jegs had them on sale for 499.99 each. My person experience has shown these heads will provide very similar power levels as the more expensive AFR heads.
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I would look seriously at the Hi-perf Vortecs sold from Scoggin Dickey with springs and a little clearancing that will allow them to handle .550ish max lift. They run around $600 and would make some pretty good power for that little of money.
You're going to want to put on a better aftermarket intake manifold when you do the heads no matter which set you choose. So that kinda removes the downside to the Vortec heads (assuming the stupid Vortec TPI manifold is ever coming out...)
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
[This message has been edited by Ray87Z (edited July 28, 2001).]
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
The Trick Flows are probably the best, you can get a set in Summit for less than $1000, and they flow right up there with the AFRs.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, LPE High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Canfield!
Look at AFR's homepage under articles you'll find "flow to go", flownumber on the most of the sbc heads.
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods, a Canfield headed 383 in the works!! ready May 2001...ok..june...july..and with Accel DFI....looking for SR or miniram....
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Port a set of Vortec's, give them a 5 angle valve job, increase the chamber from 64cc to 65cc, add screw-in-studs, add some 1.5" roller rockers, and they turn out to be EXCELLENT heads!
Corey Turner - Toledo, OH
91 9C1 - "Project Potent Rodent"
www.geocities.com/kidkid911/index.htm
-350ci / Ported Vortec's - 10:1 Compression
-Crane '509 lift hyd. roller cam / 1.5" Roller Rockers
-Ported Holley 670cfm TBI on a Edelbrock Multipoint EFI System / Paxton AFPR
-Heddman Full-Length Headers piped to Dynomax 2.5" True Duals / DM Turbo Mufflers
-K&N Dual Air Inlets running to Ram Air II Hood
-MSD 6A Ignition Controller / MSD Blaster 3 Coil / Accel wires-cap-rotor
-Ed Wright Fastchip in a 7747 ECM
-Flex-a-lite 210 Electric Fans - 160 Thermostat
-700R4 w/ a B&M Shift Kit
-3.43 Posi-Rear
-Ram Air II Hood, Custom spoiler
-3.43 Posi-Rear
Guest
Posts: n/a
Iroc N Roll, as far as the heads I'd have to agree with the modified Vortec's if you could get a TPI intake for it. Since you can't right now, I'd say Trick Flow heads. I haven't seen any test on the canfields to know how they stack up. How do you like the Hurst Dual Gate? Any Problems?
1 Post
The shifter is ok. Installation kinda sucked. The wires for the neutral safety switch were too short for the new base. I had to take apart the dash to go in and give the wires some slack. Other than that it wasn't so bad. It looks really cool and shifts pretty nice. I haven't had any problems with it. I can't say that it has helped performance any but at least its fun
1985 IROC-Z w/T-tops, 305 out and 350 L98 TPI engine in, Hooker Super Comp Headers, 3" Hooker Super Comp Cat-Back, 3" CatCo Cat, Rebuilt TH700R4 with Shift kit, 3.73 Richmond gears, Auburn differential, Accell SuperCoil, Accell 8mm racing wires, BBK AFPR, Homemade Ram-Air (thanks to Andris Skulte), MAF screens removed, Dropped A/C, Dropped A.I.R, TB coolant bypass, Hurst Dual-Gate Shifter, Air Foil, K&N filters, Holley performance fuel pump, Spohn Subframe Connectors, Re-located Spohn Lower Control arms, and more to come.
Canfield flow numbers are:
195cc ports
220cc ports
The E/I ratio is okay for carbureted motors(low 70's), but the exhaust ports could definitely use some work for port-injected mills. Then again, at these prices whose to complain?
"The reasonable man adapts himself to the world.
The unreasonable one persists in trying to adapt the world to himself.
Therefore all progress depends on the unreasonable man"
--George Bernard Shaw.
195cc ports
220cc ports
92projectcamaro
01-18-2016 08:00 AM
