Good mechanical gauges?
Who would you guys recommend getting gauges from? Autometer seems to be thrown around alot, any other companies I should look at?
F.Y.I. needing fuel level, oil press., coolant temp, volts, tach,tranny temp, and speedometer. Getting NOS gauges and fuel pressure gauges from NOS systems.
Also, how hard are mechanical gauges to hook up? I have heard they are more accurate. More expensive than elec? Do I need all that damn wiring also? I hate wires..hehehehehe.
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
All my gauges (in all my vehicles) are Autometer Mechanicals.
Fuel Level and Volts are always gonna be electric though.
Mechanicals are not much more expensive than good quality electric gauges (usually) and are definitely more reliable.
Only wiring on the mechanicals are for the lights.
See the catalog:
http://www.autometer.com/hp/
-Rich-
See the catalog:
-Rich-
i am running mechanical guages where i can as well. I'll have all autometer guages this year when I'm out. Should be a lot more accurate....just was working on another member's IROC last week and ALL his guages were inaccurate compared to the scan tool at my auto shop class. The tach, volt, etc. were all off from the scanner's readings.
I've always been partial to Stewart-Warner Heavy Duty gauges. I think they more closely match with the factory gauges, if you're into that sort of thing.
I like Autometer, but some of their high-end gauges aren't available in 2-1/16" sizes.
I prefer mechanical gauges because mechanicals usually have a wider scale sweep; 270 degrees vs. 90 degrees for electrics.
Originally posted by 88ROC1LE
Thanks for the link, and thanks for giving me another company to look at. Mechanical it is, and to hell with the wires! Stewart-Warner have a online catalog?
I buy my SW stuff from these guys:
https://store.tolosatech.com/xks/
Be aware that SW stuff isn't as "cool" looking as some of the more modern stuff...no white face, glo-in-the-dark, etc. Pretty much old school (like myself).
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I like the dark one's also guys. Thanks for giving me another link. I want to set me up a nice custom cluster using black gauges, and wanting to stay as far away as elec wires as possible(bad lightining experience as a kid ) Any of you got pics of your clusters? Send them to me if you don't mind!
Ghettobird52
07-05-2024 11:18 PM
R3500
08-17-2015 12:16 PM
