Bosch platinum +4s
Bosch platinum +4s
I was thinking of getting a set of these spark plugs but they are kind of spendy. Wondering if any of you guys are running these and how do you like them. Thanks.
1 Post
Car: RS
Axle/Gears: 9" for the ladies
all they do is block spark from getting out. thats not good. they do however last longer since there is 4 prongs to burn off.
i use regular a/c delco
Can you say gimmick?
No seriously there may be some slight performance gain from exposing a fatter spark to the incoming air fuel but how much of a gain? Probably next to nothing. Might be enough to make you pass the sniffer test if you're just squeaking by.
Car: Red Rooster
Transmission: M5
I had them for about a year and found "0" performance gain and "0" gas mileage gain compared the stock AC Delcos.
IMO, they aren't worth the $. Save your money for something else.
Car: projects.......
If you want a nice plug go rapidfire, otherwise, just run regular AC's. I used-to work at Autozone. We had sooooo many complaints on those Bosch's it ain't funny. I think I heard maybe one little import kid saying that he picked up like 50hp if you know what I mean. He had 200,000+ on OE plugs so then yeah, he noticed a difference...
Car: 1990 Firebird Formula
I too used to work at autozone and sold the hell out of regular bosch platinums... I've also used them in 4 or 5 motors and have found them to be great plugs... I however would NEVER spend $5 for a plug so automaticly would not touch the +2 or +4...
My only bad experience with any plug was with ac delcos in my 305 TBI car.. it sat all winter and the plugs fouled so I couldn't get it it start in the summer... I switched to Bosch Platinums and this spring had no problem starting the car...
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
This is my opinion, and I have no hard info to back it up, but those plugs still only make one spark. But now its divided up by 4 electrodes. So I don't think all four individualy are as strong as 1 spark. Aren't those Platinum plugs? I think they offer a greater life, not neccesarily greater performance.
I just got the accel shorties, only cuz of the headers. Spark plugs are spark plugs they make a lil spark and ignite the fuel/air mixture how much can you possibly improve on them?
Car: 1997 Camaro z28
Engine: 350 LT1 built to LT4
Transmission: a
Axle/Gears: 3.23 posi
Platinum +4's rock....they are kinda expensive though. I got some for my camaro and i saw some gains, but not all that much. Although I used to own a minivan(i still miss it), and i gave that 4 banger platinum +4s and saw crazy gains, i mean crazy, were talkin 165,000 miles, 89 engine, treated like ****, leaked and burned oil like crazy, so on so forth, i swear when i gave it taht tuneup (oil change, bosch plugs and wires, fram filter), i swear it ran insane speeds, like 0-60 in 7 seconds, it was crazy, although i will say that 2 weeks after i spun a bearing...hehe.
I still miss that awsome minivan....
Car: Camaro
Engine: 355
Transmission: th-350
Axle/Gears: 3.73 welded
Ok let me see here .... electricity will only take the path with the least resistance ...so this means these plugs will not make 4 sparks since it is impossible to get each electrode to have the exact same amount of resistance and then you can hope the spark will split not counting all the other variable included in it .. the combustion chamber is a pretty hellish place and the electrodes will get some gunk on them ... they will make ONE spark. so IMHO these plugs are worthless ..they are just something for the people that dont have much experience with cars ..and electricity to spend money on.
Transmission: a
no one, not even bosch said they make 4 sparks...all its designed to do is increase your sparks options. If your spark takes the path of least resistance, and it only has one path, no matter how much resistance there is, its gotta go that way, which means that it will probably be somewhat weaker when it gets there, especially on older plugs and wires.
What Platinum +4's do is give the spark 4 different paths to take, and obviously the spark chooses the easiest, giving you a constant somewhat stronger spark. Also, because they're platinum, and because there's 4 different electrodes, the spark plugs have a significantly larger lifespan, and also will work like new for far longer then other spark plugs, so they definitly aren't worthless, they're just expensive as hell.
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I got em in my ROC... Gains? I have no clue. I had the money and didnt know what I was doing so I purchased them. Atleast I know that when they do start to foul out I can get me another set for free!, they come with a limited lifetime warranty which means I can exchange them once I think. So with that said Im actually paying $2.50 per maybe less....Im happy!
So figure thats another way to look at spending the money on them.
HEHE! I just looked at my receipt and I got the plugs on 9/14/2000 and put them on the shelf and I just put them in last year when the car had 120.635
they only got about 12000 miles on em so I got a long way to go til I need to replace them.
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
I have always had good luck with splitfires.. the regular ones not the ones that cost 8 bucks a shot..
the bosch platinums use the lowest amount of platinum out of any plug on the market if you really want to spend the money on a platinum plug get NGK, champions or any other type of plug. just thought you guys would like to know
Car: 1987 Trans Am
Engine: 350 tpi
Transmission: 700 r4
Re: Bosch platinum +4s
I put boch platinums in my trans am and noticed that the car ran smother and idled better but might just be because my old plugs wher realy old thats my 2cents
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
holy 4 year old thread resurrection batman!
...AC Delco all the way.
Car: Camaro
Engine: 355
WOW ... haha i just got an email that this was posted on !! hahha ... resurrection for sure man
amargari
11-10-2015 02:09 PM
HoosierinWA
10-07-2015 10:15 AM
