How much does a complete TPIS Mini-Ram cost?
I checked their web site but I guess you have to buy different stuff for it. What does one cost complete?
Founder of the Greater Cincinnati F-Body Association
1988 Yellow Trans Am GTA
Click here for photos
With the cost of the MiniRam itself ($895), fuel rail ($355) and chip ($575), the total cost is $1875.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
Car: 04 GTO
Transmission: M12 T56
The chip is not $575, it's more like $275 for a pocket programmer, tunercat w/ .tdf, and some flash PROMs. Spending $575 for the TPIS chip is assinine, their chips never run very well, even in basic combos.
...ed
edit, just thought i'd add that the cost of the burning equipment shouldn't count w/ the manifold cost anyway, once you are seriously modding your car (hell even if relatively stock), burning is the only way to tune.
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
[This message has been edited by Ed Maher (edited July 12, 2001).]
...ed
Car: Death Mobile
Engine: 666 c.i.
<font face="Verdana, Arial" size="2">Originally posted by Ed Maher:
...ed
</font>
...ed
</font>
Also, if you want to learn about eprom burning, you are better off to learn while you still have a basically stock engine. You can make your "mistakes" and still have your old Memcal/BIN as a backup.
Eprom burning is a lot easier than most people think it is. There is an initial learning curve, but you once you get over that "hump", its a snap. If an old fart like me can figure it out, anybody can.
Complete with fuel rails and Miniram = $1,250 + shipping.
The AFPR is prolly another $100 being it's god-awful expensive TPIS that we're talking about here.....
I talked to them about 2 months ago and that was the answer the rep gave me.
HTH,
Brian P
89 IROC-Z 355(soon to be minirammed and cammed with a bigger shaft, puny 214/220 just ain't cutting it)
Turbo 700(TC Clutchless wonder, god this tranny is impressive)
HTH,
Brian P
Not to mention:
Cam and valvetrain upgrades: $350+
Exhaust(if needed): $600+
Cylinder head upgrade
(if needed): $500 - $1500
Drivetrain upgrades: $800 or more
Suspension: sky's the limit
etc., etc.,....
Not trying to be a downer. I'd love to own a Miniram, it sounds like the ultimate way to go EFI on a SBC. But when I look at everything that needs to be done to realize the potential of this type of motor, well,...(shudder). If ya got the dough, definitely go for it, but use the experience of the folks on this site(especially Trax), so ya know everything you're gettin in for.
"The reasonable man adapts himself to the world.
The unreasonable one persists in trying to adapts the world to himself.
Therefore all progress depends on the unreasonable man"
--George Bernard Shaw.
etc., etc.,....
if you're converting from carburated induction you'll need the mini ram stand alone kit complete with everything, and it's $3750. I fyou already have TPI, then you'll just need the fuel rails, plenium, computer, and wiring harness.
Car: Death Mobile
Engine: 666 c.i.
<font face="Verdana, Arial" size="2">Originally posted by iroc5speed:
If you already have TPI, then you'll just need the fuel rails, plenium, computer, and wiring harness.</font>
88Irocs comment is valid about needing all the other parts. A Miniram by itself is probably not a cost effective mod. But match it with the right heads and cam, and you can have a lot of fun.
Terrell351
06-13-2021 01:13 PM
Sanjay
08-12-2015 03:41 PM
