How many of you have high performance crate engines?
And where did you get them from.
Founder of the Greater Cincinnati F-Body Association
1988 Yellow Trans Am GTA
Click here for photos
1 Post
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Check sig.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
86 Camaro Sport
My Camaro Project
Ugh! Dont go to speedomotive! They use cheap parts and they know very little about engines... I have two friends with their engines and first-hand experience with how bad they are.
I'd stick with GMPP engines, or a local engine builder you know and trust.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Check the sig!!
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Recently Ported Heads, Installed Larger Race-Flo Valves, RPM Air Gap Intake, and 1 3/4" SLP Headers (No new times)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
The Bowtie
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
The Bowtie
1 Post
Engine: 4.0L
<font face="Verdana, Arial" size="2">Originally posted by Kevin91Z:
</font>
</font>
They do have bottom end stuff but let you upgrade to anything you want. Cheapest priced performance crate motors around.
86 Camaro Sport
My Camaro Project
Yep, that SpeedoMotive. You know they've moved at least 3 times in the last 5 years... I wonder why. They may have been good in the past, but lately they suck. One friend bought a 400 small block engine from them. From the beginning it sucked oil, idled terrible, and didnt make the advertised power. He went back to talk to them about it, and they basically told him "tough crap". Then when they found out he is a lawyer, they got all apologetic and offered to redo the engine, but instead they gave him his money back and he went elsewhere.
The other friend purchased a 383 kit from them, using Sportsman II heads. He told them it was a street car, he wanted torque, good gas mileage, and has to pass California emissions. They put the heads on untouched, didnt clearance the heads for the centerbolt valve covers, and didnt open up the EGR passages. They used a roller block, but sold him a flat tappet cam with 110 lobe centers because "it will make more power". That engine also burned oil, a quart every 800 miles, ran like crap, had no torque until 4000 RPMs, and got 9-10 miles per gallon. The guy took it to my dad to "fix it". He called Speedomotive and they told him to bring the engine to them to look at. They offered to rebuild it for free. When my dad got it back, he found they hadnt cleaned up the pistons, they put cheap rings on it, and didnt even hone the block. Also, they threw out the lifters, making the flat tappet cam worthless. When my dad called to ask them about it, they told him "tough crap" and "they dont save used lifters".
For these reasons, I am putting SpeedoMotive on the blacklist. Yah, they have cheap prices, but you get what you pay for.
What does your car run John? Just curious. I am probably going to go through American Speed or Golens Engine Service. They have motors designed for 86-92 TPI cars.
I, too, have heard that Speedo has been hurting the last 12mo or so. Not verified by me and not sure what "hurting" means, but I heard it from 2 seperate individuals that work "in the industry".
I vote for ZZ4 short block, FastBurn heads, GMPP HotCam with GMPP 1.6 SA roller Rockers. Basically, a FastBurn 385 with the Hot Cam and 1.6 rockers added. No bull 430hp/400+lb-ft with only a 218/228 @.050" duration camshaft. Great numbers and quite streetable. Too, has a warranty that should be honored unless GM goes out of business....
I had the gmpp vortec headed crate engine. It was rated at 330hp/~370ft/lb from gm. I had the heads worked over - springs,valve job,port,ect and added the XE268 cam w/ 1.6rr's. It ran pretty hard in a 5 speed IROC - I did go the cheap route however, and used a the rpm intake and holley DP instead of tpi.
1 Post
Engine: 4.0L
<font face="Verdana, Arial" size="2">Originally posted by BrianB:
</font>
</font>
I am limited from getting into the 7's by the STOCK TPI intake I'm currently running.
86 Camaro Sport
My Camaro Project
