Single plane intake manifolds
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I have a Torker II on my car, it works but it's mismatched to the rest of the engine. Should clear the stock hood, but I think hood clearance is the only reason you'd want one rather than a taller single-plane.
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
We used a Weiand X-Celerator on my friends 84 Camaro. It ran damn good, and no clearance problems.
Joshua Johnston
1991 Z-28
Flowmaster
K&N
305 / 5spd. (Temporary)
Joshua Johnston
1991 Z-28
Flowmaster
K&N
on the weiand webpage the picture for the 7525 looks like it's for a spreadbore carb but the webpage also recomends a 750 - 850 CFM Holley HP. I have a square bore holley vacume secondary 750cfm carb. I will need an adapter plate for this to work on this intake right?
The 7525 has provisions for both square and spreadbore carbs. The low rise 7547 will fit under the hood and I've them with very good results for the money. I've seen them flow rated at 250 cfm per runner, so it could restrict the better flowing heads. I'm not sure if the taller 7546 will fit under a 3rd gen or not.
92projectcamaro
01-18-2016 08:00 AM
86CamaroDan
09-29-2015 10:08 PM
