Rhino Ramps... awesome!
Car: Check The Sig
I just wana say that if anyone is looking for ramps for there car, go get Blitz Rhino Ramps... i payed 31.95 for them at Advanced Auto Parts... it can be found in pep's and walmart too, there nice and they dont scrape... now i need to go home and start workin! hehehehe...
87iroc_z (06-02-2021)
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
I've got to give Rhino Ramps a big thumbs up, too. I've had them for three years now and they are great. Nice and wide, too.
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I got some Rhino ramps a few weeks back from Pepboys on sale and with free wheel chocks. Makes oil changes a breeze!
Originally posted by ThirdGenZ28 92
I was just going to ask, do they work with lowered cars??
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Originally posted by Benny
I used them on my B4C when I had the prokit on there and they work ok, I had to lift up on the front end (manually) just a little to fit them in, probably a better choice for lowered cars are the metal ones and use the optional extension ramps.
Car: Damn
Engine: This
Transmission: New Stuff
I have them too. they are great ramps and pretty cheap.
My '88 gets on them no problem, but the larger front GFX of my '92 won't clear, I have to use some boards to step the car up onto the ramps.
It sux for our cars because of the huge front overhang we have.
Nonetheless, they make life easier!
Originally posted by bigals87z28
how come?
how come?
It's no big deal anyway. Once you get subframe connectors, jacking up the car is actually easier than using ramps.
__________________
1989 Rally Sport
1986 Z28 ASC McLaren convertable SE #41
A moderator at www.thirdgen.org
A moderator at www.fl-thirdgen.org
"'Tis an ill wind that blows no minds." - Discordian Quotes
I have some kind of black ramps and they are hard to get up my litle plastic piece under my car scrapes a little.. by the ways its a 87 firebird...but my brother has a 97 eagle talon and we had to put boards un his to walk it up but they do make oil chaning a breeze i give them two thumbs up to.!
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
i bought a set about a month ago and my car barly fits on them, but it fits if the ground is level, i dunno how they are about changing oil with, never tried it. but then working on the car it makes it alot esier when you have a pit.
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
I have a set that I bought for $31 at Autozone a year ago. Nowadays, Wal-Mart has them for $16.88!
88 WS6 TransAm GTA,
I use them on the front of my '92 GTA with no problem. Doesn't hit the GFX. They did knock off the deer-scarers that the previous owner installed though. Those hung down over 1 1/2".
88 WS6 TransAm GTA,
Engine: Twin 454's
Re: Rhino Ramps... awesome!
My guess is that you will be okay, HisDivineShadow, though I've never had a GTA. I never had any problem with my '92 Formula and have only the slightest of issues with my '87 and '90 IROC's and '91 Z28.
Good luck.
Good luck.
Axle/Gears: 3.45, 3.27, 3.27
They will work on a lowered car (in my case a RS with Eibach Pro-Kit) if you take a hand saw and cut down the lip at the rear of the ramp. I have a lot of trouble with them wanting to scoot out from under my car. I've even tried the trick of attaching a rope to it and driving onto the rope before driving onto the ramp. It could be that my garage floor is too slick. Because of these hassles my preferred method is to jack up the front and use jack stands under the A-arms. When I do use the ramps I'll just jack up the front of the car then lower it onto the ramps.
Lon
Lon
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
I picked up some at AutoZone a few months ago. I haven't used them on the front wheels but I did back onto them fine without scraping. Pretty cool product.
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
Lon
Lon
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
my 89 formula is lowerd and uses the 82-83 T/A air dam which is deeper than the stock formula dam and i bump the air dam on the ramps when i use mine. my issue is when i roll up on my ramps mine slide and yup that lil rubber foot is on there, i screwed it thru the side to make sure it stayed put. mine slide due to my floor, its epoxy coated.
now on stright out concrete, they grip like a merf and work killer. if ya just brush the underside of your car i wouldnt sweat that but if your diggin into the ramps then thats where i would have concern.
Abubaca
11-05-2016 12:22 PM
86CamaroDan
09-29-2015 10:08 PM
