Jeg's High Flow 220 Heads ?
Has any one used thes, know any one that has? Here are the specs:
220cc intake runners
.150" offset intake rocker required
1.550" springs- 1.875" install height, 240 lbs. seat pressure
64cc CNC-machined combustion chamber with angle plugs
10deg. locks, steel retainers and bronze guides
2.100" intake and 1.60 exhaust stainless steal valves
7/16" rocker studs and 5/16" guilde plates included
They go for around $690 each assembled. I am purchasing new heads for my set up(details in sig) and am looking for heads that will give me great performance. I am looking at AFR heads, but these seem to be better. I am just curious if any one has tried them.
The heads are canfields. They are not as good as the AFR, (my Opinion) I am NOT a professional engine builder and dont care to hear who has the best heads. I am only trying to help.
I have run 11.95 w a flat top 350 and chevy camel heads with a hydrolic cam. I will use my new AFR head with my freshed engine. I have not conducted back to back test yet. So I do not have any personal experience
If you call AFR they will build the heads to fit your needs. Ie Mill to correct chamber CC. Correct Valve Springs, Valve Length, etc. I was most impressed with their professionalism. Do not buy any heads from them without talikng to a sales rep. You will not receive the best benefit, the heads I finally received are not a listed combination. You get what you pay for.
I will take up to 6 weeks to get the heads if ordered from AFR. Some othe the sponsored vendors may provide a better turn around time due to their pull with AFR.
The differential in cost is small compared to installition down time etc.
Mickeyruder
09-02-2015 02:45 PM
