406, 6" rods, and oil pan clearance w/in
1 Post
Car: 2000 Trans Am
I got to the point of bolting my oil pan onto my 406 today and where I had to clearance the oil pan rail, it hits my oil pan. Ive tried knocking it in, and while that may work, I wonder if there was a better way to avoid riggin it to work this way.
-86 IROC
Vortech stuffed EFI 406 in progress
-=ICON Motorsports=-
-86 IROC
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
If it makes you feel any better I have the same problem. I bought a generic pan from summit and the part nearest the rear main hits the pan. It just does make contact.. I thought about using a ballpeen hammer on it also but im worried about oil leaks.
Are you using a stock 400 pan? I think that would have the extra clearance. But its nothing trick.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
1 Post
Car: 2000 Trans Am
Shop said to beat on it.
Im going to get a propane torch, heat it, bang on it with a ball peen hammer.
Doesnt take much clearance. .060
Hotrodboba400
12-10-2019 07:07 PM
New2Chevy
09-28-2015 12:35 AM
rudolphschenker
09-04-2015 02:41 AM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
