water pump
water pump
I have about $3500 invested into my engine and i am still using a stock water pump(what can i say im dead broke right now). I want to get an aluinum water pump that will circulate the coolant better than my stock pump. But i dont have alot of money to spend. Any suggestions on a good bang for the buck pwater pump? thanks alot
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLp siamesed runners, Edelbrock high flow intake
*Edelbrock TES Headers (getting SLP 1 3/4 this summer)
*Richmond 3.73
Modded 700-R4, 2800 stall converter
NO recent time slips.
*1989 RS
*355 CID
*Richmond 3.73
hey man I hear you about being broke. I used the stock pump on my 383 when I put it in. Anyways right now I have the Edelbrock Victor Series Water Pump. I got it from Jegs for abou $150. Seems to be pretty good. There is a rebuild kit for $60.
http://www.jegs.com/cgi-bin/ncommerc...%202231%202232
87 camaro Replaced the LG4 with a 383.
My website http://www.87camaro.8m.com
79 MGB Stock and not entirely mine.
MGB website http://www.mymgb.8m.com
Well, thanks for the replies fellas. i guess i know where ill be spending my next $150.
*1989 RS
*355 CID
*Richmond 3.73
*1989 RS
*355 CID
*Richmond 3.73
Car: 91 Red Sled
Stewart waterpumps. I'm gonna leave it at that. Either you get the best or you pay in the long run. They have STAGES so you don't need to get the top of the line. I went with a stage 2 unit and it cost me $160, $10 more than edelbrocks but from what I've been told, it's the best $10 difference. These guys do nothing but cooling and they're used in NASCAR more than edelbrock, maybe for a reason! Edelbrock is good, don't get me wrong, but Stewarts takes the cake. Look at the units, if you really don't have a lot of money then get the stage 1, it'll work GREAT and has all new parts.
, Jon (350 TBI!)
91 Red My website
, Jon (350 TBI!)
91 Red My website
1 Post
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I second the Stewart pump. I got a stage 1 and it flows like mad.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
86 Camaro Sport
My Camaro Project
Car: 89 Formula 350
Engine: 360 / HSR
Meziere electric water pump. Flows 35 gpm constantly. No belt driven pump can come close to that.
http://www.meziere.com/
Jed
89 Formula 350
Jed
89 Formula 350
1 Post
Engine: 4.0L
<font face="Verdana, Arial" size="2">Originally posted by Jed:
<A HREF="http://www.meziere.com/" TARGET=_blank>
http://www.meziere.com/[/url]
</font>
</font>
Here's a comparasion between edlebrock and stewart with flow rates.
http://www.stewartcomponents.com/ede...comparison.htm
Car: 1972 Corvette
I have the Edelbrock also. It has been on my car for over 3 years.
'94 Corvette Admiral Blue
-==ICON Motorsports==-
'91 Z28 Blue/Silver ZZ4/ZF6
335.9 rwhp 374.9 rwtorque
Car: 89 Formula 350
Engine: 360 / HSR
John,
Those are pretty impressive numbers. I live in a highly populated area, so it isn't uncommon to spend just as much time idling in traffic as I do cruising. I also like the fact that I can cool down the engine by running the pump with the engine off. And I wanted to eliminate belt driven accessories. For those reasons the meziere unit meets my needs.
I didn't think a belt driven pump could flow that much. I wonder how much flow is really needed - I drive my car daily and don't have any overheating issues.
Thanks for the info,
[This message has been edited by Jed (edited May 28, 2001).]
1 Post
Engine: 4.0L
John,
Those are pretty impressive numbers. I live in a highly populated area, so it isn't uncommon to spend just as much time idling in traffic as I do cruising. </font>
John,
86 Camaro Sport
My Camaro Project
1 Post
Engine: 4.0L
<font face="Verdana, Arial" size="2">Originally posted by camaroguy99:
Does stuart make a reverse flow stage 3 or 4 pump for '87 and later applications?</font>
http://www.stewartcomponents.com/index.htm
86 Camaro Sport
My Camaro Project
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Do you mean reverse flow, or reverse drive? The only engines that require reverse flow are LT1s and LT4s. If you have a serpentine belt, then you need a pump with reverse drive, right?
Maybe this will help. Only LT1s and LT4s are reverse flow engines as was previously mentioned. Ours are reverse rotation water pumps, they flow the same direction as a standard or normal sb chevy they just turn backwards. It has a differant impeller made just opposite of a normal rotating pump. Hope this cleared it up for everyone.
Steve
Steve
