Ford motorsports injectors, did i get screwed or what??
A while back i bought ford motorsports injectors for my 88'305 TPI. I was told by many that it would fit and there should be no problems. I lost my stock injectors, cause im doing a major rebuild. About a week ago i found the stock injectors and the ford injectors are about 3/4 of an inch shorter than my stock ones. Is there gonna be a clearance problem. will its still fit. Please tell me someone has the same injectors and they fit fine.
Car: Damn
Engine: This
Transmission: New Stuff
Vortec, they will work.
Ours are longer because of an older design that uses a wierd tip to help the spray i guess. Most new injectors are like the ford ones, its just a newer design.
Just make sure the slots for the injector retainers are in the same places.
Alot of people run them with no problems.
Good luck.
'88 RS (originally 2.8)
-350, .040 over, vette alum. L98s, stock tpi.
-305 injectors & chip
-TES headers & edelbrock cat back
-3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 356-13.7@101mph
on a 2.050 60 ft.
(Damn the 2.8!)
Good luck.
-3.73 gears, 700r4.
on a 2.050 60 ft.
(Damn the 2.8!)
