G-tech times compared to actual 1/4 mile times
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
For those that have used a G-tech, how do your times compare to actual elapsed dragstrip times. My times have been very comparable but my MPH has been 5 or six higher on the g-tech. Comments??
1991 Firebird
350 L98 (was a 305 TBI)
T-5 transmission
Edelbrock TES and cat back
Accel manifold
NOS
subframes
jegster torque arm
MSD Digital 6
AFPR
Lakewood lcas
Hurst linelock
SLP cam
relocated battery
cold air
Hypertech chip
centerforce clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
a/f gauge
autopower rollbar
14.0 at 100 NA before heads
Juice and AFRs??......TBD
My 1/4 mile times have been within .2 of my times at the track but the mph on the g-tech is always about 5mph high. I've heard that this is because the g-tech gives you the speed at the end of the 1/4 mile while the track gives you an average speed over the last few feet of the track.
best 1/4 mile so far: 13.4 @ 101mph
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
M/T ET street tires
1 Post
Car: 1989 Formula 350
Engine: 355 HSR
Transmission: Rossler 700R4
Axle/Gears: 9 bolt/3.27
JBENGE is right its in the owners manual.I used my G-Tech at Muncie, IN Raceway in 88 degree heat the G-tech showed 14.38 at101. Track time was 14.65 at 95.5.
89 formula 350, 73000k, 9-bolt 3.27, gutted MAF,dynomax muffler,gutted air box,kn,accel coil wires,dunlop 60/235
g-tech best(9 runs)14.48@101.1 0-60=5.91
track best(3 runs muncie,in 88 degrees)14.51@96.0 60' 2.089
in the garage waiting to go in are alum. L98 heads(bowl job by scoggins-dickey),ported high-flo edelbrock base,SLP runners, Jethot coated SLP 1 5/8 headers,zz3 cam 208/221 .474/510,1LE alum. driveshaft,TCI 2200 stall,LPE feul reg.,TPIS air foil,Flowmaster ForceII cat back,Gold crane 1.5 rollers,Eagle forged 5.7 rods,TRW Speed-Pro forged -21cc dish pistons,lots of ARP bolts,
[This message has been edited by L98FORM89 (edited May 13, 2001).]
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I think mine is fast by 2.5ths and my MPH is about 6 more in the 1/4 mile.
89 T-Top GTA 350 5-speed (soon to be 6-speed)
(Jet hot coated)1 3/4 SLP headers,flowmaster force 2,no cat's,SLP cold air,MSD 6al,jet chip stage 2,march pulleys,ported plenum,air foil,B&M ripper shifter,180 stat,alston SFC,spohn LCA relocation brackets,free mods.
G-Tech times
0-60 5.2s
E.T. 13.91@104.8MPH (2300ft)
G-Tech times
0-60 5.2s
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Yea I read an article in Popular Hot Rodding about the G-Tech and they said their's did the same. It was about 1-2 tenths off and higher speeds than the e.t. slips showed. I guess the speed calculated at the strip is averaged over the last 60 ft. The G-Tech figures it right at the 1/4 mile mark.
Car: 1991 Firebird
Engine: 427 LSX
Well, I ran mine with the heads the other night and ran 0 to 60 in 5.01 and the 1/4 in 13.46 at 108.8.
