AutoXray
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
AutoXray
I was looking at AutoXray and I wanted to know from anyone out there what sensors do our 3rd gen's have that can be read by this scan tool? I know on my brother's 99 Z28 we can see data with the LS1Scanmaster such as air inlet temp, O2 readings, fuel trim, mph, rpm, and coolant temp. I just wonder how many sensors AutoXray could actually pull data from on our cars.
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
Autoxray/EZ Link scanned data
From my 92 Z, here were the sensor/signals read:
Prom ID
Coolant Temp
Startup Coolant Temp
Throttle Sensor Volts
Throttle Angle %
Engine RPM
Vehicle Speed MPH
O2 Sensor mV
O2 Cross Counts
Block Learn
Block Learn Cell
Integrator
Idle Air Motor Position
Desired Idle RPM
MAP Sensor Volts
Manifold Air Temp F
EGR Duty Cycle %
CCP Duty Cycle %
Battery Volts
Fuel Pump Sense Volts
Learned Idle Position
Oil Temp
Spark Advance Degrees
Knock Sensor
Knock Retard Degrees
Injector Pulse ms
Engine Run Time secs.
AC
AC Forced Off
Battery Voltage High
Shift Light
TCC Status
Park/Neutral
Fan #1
A/C Clutch
O2 Sensor
Fuel Cut Off
CCP Purge
Air Diverter Solenoid
Air Switch Solendoid
Learn Control
Rich Lean Flag
Loop Status
Prom ID
Coolant Temp
Throttle Angle %
Engine RPM
Vehicle Speed MPH
O2 Sensor mV
O2 Cross Counts
Block Learn
Block Learn Cell
Integrator
Desired Idle RPM
MAP Sensor Volts
Manifold Air Temp F
EGR Duty Cycle %
CCP Duty Cycle %
Battery Volts
Oil Temp
Knock Sensor
Injector Pulse ms
AC
AC Forced Off
Shift Light
TCC Status
Park/Neutral
Fan #1
A/C Clutch
O2 Sensor
Fuel Cut Off
CCP Purge
Learn Control
Rich Lean Flag
Loop Status
Engine: 2.8L V6
Well the older the car I would assume less sensors so less to monitor. I doubt on my car I have an oil temperature sensor but heck I guess it's always possible. Maybe I should look into buying it and play around with it. Thanks for the list KevinP92Z.
I have the auto x-ray for OBD-1, this thing is great, highly recommended, sometimes prices vary, but I paid $160 for this one. The auto x-ray with all of the pig-tails and case was about $360. Jiffy lube had the same auto x-ray and charging people $14 per scan. These things are a great investment.
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
1 Post
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
Originally posted by 87Formula391S/C
where you buying the auto x-ray for OBD-1 at?
Sammy
Sammy
Jed
Aftermarket Product Review
10-13-2003 09:12 PM
I ROCK
01-12-2001 12:02 AM
