FOrd motorsport injectors(its all a big lie)
As i got mines from summit the ford 19lb injectors were one inch shorter than stock. Is that a problem. The injectors are going into an 88' 305 TPI. Did summit screw up or could i still install the 1 inch smaller ford injectors. Please tell me someone had the same experience and there were no problems installing them. Help
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
92' camaro
Soon to come!!!
Other car;
The stock retainer clips right???
92' camaro
Soon to come!!!
Other car;
92' camaro
Soon to come!!!
Other car;
Car: 90 GTA
Transmission: TKO
Axle/Gears: Stock
I put 24# Ford injectors on yesterday (still haven't ran the car). You have to use the old clips, but on mine new Ford injectors there were two recesses it could have gone in. The one that was only recessed half of the circumference, the other was a full recess all the way around. If the clip fit in the half recess, then the injector would have been dead even with my former 19# stock injectors. The clip wouldn't fit right so I used the full circle recessed part and it was 1/8" off. They still went into the intake fine. hoepfully I can test it today...
Fredzep
90 GTA 350 5Spd
TPIS, SLP, Borla, K&N Mods
Fredzep
90 GTA 350 5Spd
