Top-Down Solutions Greaseable 36 mm Bushings
Lon Salgren's Top-Down Solutions has modified Guldstrand's 36mm poly bushings to be greasesable. Along with ES's greaseable 24mm rears (15/16), the improvement is considerable and well worth the money (previously I was using GM's higher durometer rubber bushings, the type used on the 1LE and, I believe, the WS6 combos). Don't waste your money on the latter. Cudos to Lon.
JamesC
JamesC
Pac J
05-17-2020 10:44 AM
