Mini-Ram owners
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Mini-Ram owners
I just got done installing my Mini-Ram and my upper raditor hose is touching my belt. Have any of you had this problem?? What did you do? Thanks.
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.6/1.52 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, Accel box & coil, Fastchips custom chip, MAC sub frame connecters, Lakewood LCA & Adj. Panhard rod, SLP 2500 stall, 3.23 rear gears, white face gagues, and NOS!
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Yes. TPIS sent you the WRONG waterneck (thermostat housing). They have a special version of the waterneck that needs to be used on F-Bodies. I know because I ran into this SAME problem. I called TPIS and they shipped me out a new special F-Body waterneck. It pissed me off but oh well - I got the part a few days later and they covered all the charges.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Tim
Engine: Miniram 383
Thanks TRAXION
Traxion.I dont have a problem with it touching the belt but it lays against my intake tubing.I dont like the hot water neck laying against the intake tubing of my supercharger.I called them up and they said they dynoed a ATI unit,and ran into the same problem.You cant even get the intake tubin on.What gives?I had to buy a older chevy crome water neck,they told me they couldnt do anything.
Car: 2000 Trans Am
It was so bad when I put my Vortech on that I actually had to cut the neck at an angle and have it rewelded to miss the idler pulley on the supercharger bracket.
-86 IROC
a few mods
this years goal: 10.50 @ 130+ mph
-86 IROC
a few mods
I had to totally fabricate a custom water neck to get my setup to work properly.
When I originally called TPIS about the problem, they said that they disn't have anything else that would work any better.
The custom fabricated one (all steel) that I made is actually the best one I've ever seen....Can ya tell I'm proud of myself??!?!
I'd call TPIS and insist they send you the correct one just as TRAX said.
86 Trans Am WS6 Black with tinted windows, shaved door handles
ZZ4, Mini-ram, true duals, LT4 HotCam, AFR 195 heads.
***Too many other mods to mention***
"In the future, cities will become deserts,
roads will become battlefields, and the hope of mankind
will appear as a stranger" The Road Warrior
Engine: Miniram 383
Thanks fellas!! I called em and they told me I had the Vette water neck. The new one is on the way....express!! Not bad.
