2.77-3.73's how?
2.77-3.73's how?
What must be done to switch my 2.77 89 Iroc 350 to 3.73's? Do I just have to buy a certain gear or other stuff. Please a listing of exactly what I need would help
Location: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
Pretty much this:
3.73 Ring and Pinion
3 Series Posi unit
gasket/lube/bearings/posi additive
Hope this helps.
3 Series Posi unit
Hope this helps.
If you already have a posi, you could just buy gears that are made for a 2 series carrier. Richmond makes them to fit in the carrier you have. They are a little more expensive, but it saves you buying a 400 dollar posi.
Engine: Twin 454's
Note! 2:77 gears=BW 9-bolt rear end. You will NOT be buying any stock gears for this set up. And with the costly 9-bolt gears you also have the added expense of the two-series carrier to replace.
Check with Miles for the parts when you have the extra $1000
to spend for parts & installation. Good luck.
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
