Anybody besides JTR sell a speedo cable adapter for T56's?
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
I'm looking for another company other than Jags that Run that either can put a speedometer cable drive in a T56 OR has a convertor that uses the VSS signal to spin a motor to drive the cable.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
Car: 1987 IROC-Z
Engine: 383 HSR, AFR 190
Look for Cable X under products on this site http://www.abbott-tach.com/
, that is what I use on my car.
1987 IROC w/T56 and a 383 TPI in the works
Engine: 406
How does it work? Is the unit pretty accurate? Thanks for the info. Would it be worth the extra $50 to get the speedo gear tailshaft for the T56 from JTR.
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
Hey Frank, JTR doesn't sell the MODIFIED T-56 tailhousing anymore, they just sell a KIT with all the part for you to do it yourself, I'm glad I got that modified tailhousing when I did. I can't imagine the hassles it would take to find a machine shop that was will to do it for you. Good luck, BTW, the JTR system works FLAWLESSLY . HTH's I got this information from Mike Knell himself.
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed/1-3/4" full length headers/3" X-PIPE assembly/ 8.5" G-80 rear with 3.73 gears.
http://community.webshots.com/user/ssynergy
www.y-t-g.com/88monte
92firebirdchris
Exterior Parts for Sale
08-14-2015 11:56 AM
Firechicken86
08-12-2015 10:07 PM
