LT4 Hot Cam, anyone know the part number??
my local dealer doesnt have up to date books and they arent really into performance that much, but he said if i could get the part number, he could get his hands on one no problem, also, is there such a thing as an LT4 Hot Cam Kit??? with lifter and springs and such?????
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
It's 24502586 for the cam and is $180 from paceparts.com or Dal at VanDevere Olds. Yes, there is a kit, and it's a pretty good deal if you need everything. It comes with the HOT cam, valve springs, roller rockers, and other misc. stuff. The LT4 HOT cam kit's part number is 12480002 and is about $520. GM Performance Parts also has a kit that comes with new roller lifters, retainers, the spider that holds down the retainers, and the bolts for the spider. I have the part number for that at home and I think it was around $160 from Dal.
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
thanks, but i dont think ill be getting one now, i did a search and there is some pretty negative feeback on the board about it being a cam for a higher revving engine, and i dont have the money for a superram or anything like that to balance it out, im only 17, so i think i might go for a compu cam from comp cams, but thanks for the info
Hey, StangEater, I am using the LT4 HOT Cam in my car, and yes, it is for sure a higher RPM cam, and if you don't plan on getting new intake parts, I would go with something a little smaller, maybe the ZZ4 Cam. However, if you have deep gears and full exhaust work, you can fully port your heads, get an intake base and port your plenum, and the cam will run like wind!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
L98 TPI 350 (5.7L)
1992 Trans Am
05-10-2023 07:19 PM
Black89TA
Exterior Parts for Sale
07-23-2016 10:42 AM
TA8487
08-16-2015 12:21 PM
