Oil Pan Clearance
Car: 89 GTA
Engine: 355 TPI
Oil Pan Clearance
I HAVE AN 89 GTA WITH EDELBROCK TES HEADERS, I WAS WONDERING IF I SHOULD GO WITH THE MOROSO 6QT OIL PAN,
OR THE MILODON 7QT. OIL PUMP IS MIL55HV
i just looked up the pan,, i dont know if your Y pipe will clear behind it. i say stick with the stock pan if your riunning a y pipe. long tube headers it would be fine, but im not sure bout these.
Car: 89 IROC
Engine: Built 383, Vortech SC
Transmission: Pro-Built 700R4
Axle/Gears: Dana 44, True Trac, 3.54
Ive got the Moroso 6qt. Jegs part #710-20182. With filter it holds 7qts. Very satisfied. The y-pipe from my Edel. TES fits between the pan and the frame cross member. Thats on an 89 350.
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I run the Moroso pan with SLP 1.75" headers into single cat y pipe (minus cat of course) with no fitment problems between headers/y pipe and pan.
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I have the 7-quart Canton road-race oil pan on my 355, and the Y-pipe for the Hooker Super Comp shorty headers fits perfectly. I did have a clearance problem between the front bottom of the pan and the center link (steering), but new motor mounts gave me plenty of room.
just stay away from anything that has a kicked out sump and you should be ok, I'm running the moroso 6 qt pan w/TES headers and it fits ok. It's kinda tough to seal the header at the doughnut and its a snug fit between the crossmember and the pan, but it works!!
