Aftermarket water pumps....which are the best for what you pay?
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
I'm soon getting an aftermarket water pump and want to know who's the best for their price. I want to pay a REASONABLE PRICE, so Edelbrock is out but I have narrowed it down to JEGS...$79.99, Weiland....65.99 for cast-94.99 for aluminum, Moroso...$109.99, Summit.....$62.99. All these are non chrome highflow units, which is what I want. Anybody have any experience w/ these of any helpful info? Thanks a lot.
I've been running the weiand aluminum pump for over a year now, and so far its been a reliable pump. I can't say it cools any better than stock, but my car always runs cool anyways, so I probably wouldn't notice the difference it did.
I really just bought it when mine went out because I wanted to save a little weight.
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
stert water pumps are the best ive seen.. state 1 is only 79.95 and it outflows the edelbrock pump
http://www.stewartcomponents.com/chevyS1.htm
67% more pressure @ 6,000 RPM
29% more flow @ 6,000 RPM
47% less horsepower loss @ 100 GPM
Stewart pumps have a 1 year guarantee Edelbrock® pumps have no advertised guarantee.
Stewart Stage 1 part number 12105 for Chevrolet small block compared to the Edelbrock® pump under identical conditions: Flow in GPM
(gallons per minute)
RPM Edelbrock® Stewart Stage 1
1000 17 18
1500 25 32
2000 34 42
2500 42 55
3000 51 65
3500 59 77
4000 68 90
4500 76 101
5000 85 112
5500 93 122
6000 102 132
6500 110 138
7000 119 148
7500 127 157
8000 139 158
1000 17 18
1500 25 32
2000 34 42
2500 42 55
3000 51 65
3500 59 77
4000 68 90
4500 76 101
5000 85 112
5500 93 122
6000 102 132
6500 110 138
7000 119 148
7500 127 157
8000 139 158
Car: 1986 IROC-Z28
I have the v-belt setup on my 86 IROC 305 TPI. I wanna change to serpentine, anyone recommend which Stewart pump to get?
Car: 91 RS
11113
1969-86 pass cars, 1973-86 light trucks
7.287" length
3/4" bearing, 5/8" shaft, High Flow Pump CW rotation for V-belts
Cast Iron Finish $79.95
11123
1987-up pass cars and light trucks
7.287" length
3/4" bearing, 5/8" shaft, High Flow Pump, CCW rotation for serpentine belt
11113
7.287" length
11123
7.287" length
Which stewart water pump or any other water pump will work well for my engine. See sig. Are the summit ones any good? I want a chrome finish at the lowest cost.
1 Post
Car: 91 RS
Engine: 350 TBI
I can't state anything about Stewart, but I loved my Edelbrock on my last project.....if I remember correctly, it wasn't all that expensive.
Tried the flowcooler (summit & Jegs rebox) didn;t notice any difference. all they do is mount a plate on the back of the impeller. don't waste your $ . the stewart is the choice of almost every circle track racer so that says quite a bit. those 9:1 motors run very hot during features. the moroso is a low drag unit not high flow.
Jubba go here, if you scroll up there are links
i just went to autozone and they had two for my car, they had either a new one that was like 25 or more or they had a rebuilt one for like 10, waterpumps last for years, so i went with the cheap one because ,you know, im a poor boy....
Hotrodboba400
12-10-2019 07:07 PM
gta892000
09-16-2015 12:37 AM
