Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
best anti-sway bar
Old 05-10-2002 | 06:19 PM
92quickbird's Avatar
best anti-sway bar
what is the best anti-sway bar for a racing and street application? why? and where is it available?
Old 05-11-2002 | 05:49 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Stock 36mm from an IROC, Z28, or WS6 Firebird is the best bang for the buck. There is no way to tell the sizes without measuring them, however.
Old 05-12-2002 | 05:46 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I have both the 34 mm and 36 mm hollow GM bars and fortunately both still have the part numbers on them, so you can tell them apart that way
The P/N for the 36 mm bar is 14094344, the 34 mm is 14094339 so hunt the boneyards. I stumble across the 34 mm bars all the time. Either bar would be a good choice. My '91 RS has the F41 suspension package and came stock with a hollow 34mm bar, 21mm rear. It now has a 24mm rear bar and handles very well.
Old 05-12-2002 | 08:10 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Should you been searching for a 1LE/WS6 hollow front 36 mm and solidy 24 mm set, please see my ad in the classifieds.
JamesC
Old 05-13-2002 | 09:44 PM
what is a good company for aftermarket sway bars? i'd like to get a new one instead of one out of a junk yard, our junkyards around here aren't that nice.
Old 05-14-2002 | 03:24 PM
AspiringGearhead's Avatar
Most aftermarket ones I've found are around 200 for the set.
It's be a lot cheaper to but junkyard ones, clean em, and have em powdercoated. Probably cost ya 100 bucks.
B
Old 05-14-2002 | 07:37 PM
ebmiller88's Avatar
Don't shy away from junkyard swaybars. They're just as good if not better than aftermarket ones and will probably be cheaper for you to get. I'd pick up the ones JamesC has for sale...if I needed a set
Old 05-15-2002 | 10:07 AM
I've got a set you can but too. They are after market, powder coated, Strange Technique sway-bars. I think they are 34 solid and 22 solid. If you reallly hate junkyard ones than these will be perfect. If your interested lemme know and I'll get you exact measurements cause I'm positive those are correct. $120 obo and you pay shipping (kinda heavy).
B
BrianChevy
Wheels and Tires
08-08-2019 03:16 PM
BrianChevy
Wheels and Tires
10-13-2015 01:33 PM
darwinprice
17
10-12-2015 12:51 AM
loud91rs
10-05-2015 11:05 PM
meeklay812
10-01-2015 04:46 PM
Quick Reply: best anti-sway bar
