What is better? TB K&N filter, or SLP cold air induction?
Car: 1991 GTA
Well it is spring, which means cars mods!
I want to either get the K&N style air cleaner that attaches directly to the throttle body or the SLP Cold air induction kit.
Anybody out there have any problems with either product? The K&N is a hell of a lot cheaper so it is looking better already....lets hear what ya think!
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
DO NOT get the K&N that attaches to the TB. It will only draw in hot air from behind the radiator and from your exhaust. The higher temps will cause a larger HP loss than the filter will gain. Go with a good cold air system or build your own. I built my own in about an hour with basic hand tools and $20 in materials plus K&N's. Knocked off three tenths in the quarter with my previous 305. No BS.
1992 Camaro Z28; Engine:383 w/Edelbrock RPM ported heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, 1.5 Roller rockers, 30 lb injectors. Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, 4.10. Super Ram.
Double-Pump This! EFI Rules!
Definition:
NOPI: n. 1. import 2. Sticker worth 47 hp 3. import with 6" exhaust tip
antonym: smallblock
Definition:
antonym: smallblock
Car: 1991 GTA
Thanks Frank.....it had never occurred to me that I would be sucking in the warm engine air...glad I asked!
Heres an idea a friend gave me , I did it on my car and it worked great. total cost was like $15.
Cut a whole in the passenger side air deflector (black plastic piece below bumper). Buy a 90 degree PVC pipe from Lowes or Home Depot, along with some dryer venting . Attach it to the PVC pipe and run it up through the passenger fender, all the way to the stock airbox snorkel. That's for a pontiac by the way.
The Camaros I believe are removing their fog lights and running cold air that way. There are some great tech articles on this site for it. Ron Mullins has an excellent one.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton 10# SN92 polished kit, Ford SVO 24#injectors, Crane AFPR,SLP airfoil, ported/polished plenum, March alt. pulley,Crane Gold 1.6rrs,MSD coil,MSD6AL (5400rpm limit),Holley 9mm wires,Ac delco R43ts plugs,stock chip,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
91 Formula
305 TPI 5speed
1LE/G92/WS6
[QUOTE]Originally posted by theformula:
[B]Cut a whole in the passenger side air deflector (black plastic piece below bumper). Buy a 90 degree PVC pipe from Lowes or Home Depot, along with some dryer venting . Attach it to the PVC pipe and run it up through the passenger fender, all the way to the stock airbox snorkel. That's for a pontiac by the way.
i had the same idea,,
and am gonna do it when i go home for easter break
Brinkkl2000
08-04-2018 08:29 AM
db057
08-11-2015 10:11 PM
