Heated 3 wire oxygen sensors??
I ve come to the conclusion that i need a heated 3 wire oxygen sensor, mainly cause of my exhaust work. I also live in a cold climate and dont want to run the risk of running the motor cold. Ive tried Summit,Autozone and nappa and none of these stores even heard about a heated 3 wire oxygen sensor. I saw one in TPIS but i think $72.00 w/shipping is a little bit too much. Does anyone know of a place that might sell these oxygen sensors.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
92' camaro
Soon to come!!!
Other car;
I have been looking for one also. The price at TPIS does not sound bad. Since Lingenfelter wants over a $100.00 for one. Can not find one at any store around here.Is the one from TPIS a Bosch?
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
'92 ZR1 vette. Bosch PN 13077.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Tim
corvette ZR1 what do u mean
92' camaro
Soon to come!!!
Other car;
92' camaro
Soon to come!!!
Other car;
It should be less than $75. the biggest problem is connecting it to your system. GM has used several 3-wire sensrs and there are several companies offering aftermarket 3-wire sensors (Edelbrock, Holley, etc) so you'll have to get a sensor and go to the parts store to get a matching 3-prong connector, as you should not have one now. THen, hook up the signal, ground and switched power wires correctly and GO FOR IT. I must say I have found that 1-wire GM sensos (ie ruck) are fine for 99.9% of apps and heat up just fine. Yeah, it might take 90 seconds instead of 23 seconds, but the ECM doesn't care! You only need a 3-wire if you live in Alaska all year long or your O2 sensor is about 4 feet beyond the header/manifold collector.
1 Post
Car: 2000 Trans Am
I had a lot of problems last season with running rich so anything that gets it out of rich condition quicker is good for me. I put one on my car.
$60 from Auto Zone. They didnt have a 3 wire harness but TRAX sent me one. Said they sell them at pep boys (dont have one around here). The black wire is the signal wire. this will hook to the wire that runs from your ECM. The other 2 wires it does not matter what configuration you hook them as long as one goes to ground and the other goes to an ignition source. For now Ive just got mine plugged into the fuse box. It works but is not the cleanest install.
Good luck.
-86 IROC
Vortech Supercharged 406
"Well, you're equipped to be a prostitute, but you're not one, are you?"
Good luck.
-86 IROC
I just bought mine last nite. 58 bucks at AutoZone. I just cut off the 3 prong connector and hooked it up to another 3 wire cable by twisting the wires toghther. I hooked it up to the fan relay on the firewall. It works just fine
92 Z28 5.7
Ported stock heads, XR270HR-10 cam, TES headers
Crane AFPR, Flowmaster catback, MSD ignition
#24 SVO injectors, 1LE aluminum driveshaft.
Best ET 13.3@107 mph
Click here to see my car at Truspeed.org
Check out Truspeed
Check out the Bin Archive
92 Z28 5.7
Check out Truspeed
I just bought the regular bosch oxygen sensor and i guess ill stick with it and get the header wraps to warm up the sensor.
92' camaro
Soon to come!!!
Other car;
92' camaro
Soon to come!!!
Other car;
1 Post
Car: 91 Red Sled
I must be some kind of lucky guy. Both my 86 and 91 camaro have the 3 wire o2 sensor already. Previous owner must have installed it.
, Jon (91 RS too many mods to list)
Are those heated o2 sensors supposed to warm enough that you can feel it with your hand?
I bought and installed bosch 3-wire sensor, and I ran heat element wire to the fuel pump relay terminal A (the hot one when ign on), but it still feels cold when I ie. turn ign on for awhile.
'89 Formula 305 TPI T-5
Check out my car HERE!
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
The BOSCH 13077 is what I have used for 3 years now. ADVANCE AUTO has them for <$50. HTH's
EDIT: I ran mine to a seperate 10 AMP fused IGNITION CIRCUIT. It will burn you when the element is hot, if hooked up correctly. Just make sure that YOU NEVER TOUCH THE BLACK WIRE WITH ANY POWER SOURCE this wire is the sensor output, and will fail if this should happen.
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed/1-3/4" full length headers/3" X-PIPE assembly/ 8.5" G-80 rear with 3.73 gears.
http://community.webshots.com/user/ssynergy
www.y-t-g.com/88monte
[This message has been edited by 88SS6SPEED (edited March 20, 2001).]
