auto-xray
1 Post
Car: 89 formula
Engine: 383
auto-xray
Is anybody useing the new ez-link auto x-ray? Does it link up any better than the XP240? The old XP240 that im using hates to link up.
Car: '94 Corvette
hmmm, I don't get that problem that often.
Are you trying to monitor while starting the car ?
How about the connectors, are they clean ?
Are you running the latest software (EZ-Link)v.1.44 ?
The biggest advantage with the EZ-Link over the XP240 is the fact that is supports more current vehicals, and you can link it up to your home computer to upload captures to there PC-Link software & cable. You can also flash the memory to the lastest version using there software. The coolest thing I did over the winter, was purchase the enhanced OBDII upgrade over the phone. (A must if you own a 96 or newer car)
BTW: I wouldn't call the EZ-Link new, I've had mine for a couple of years now.
Ron
EZ-Link ProPack w/Enhanced OBDII
Ron
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Location: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
A heads -up on the "not responding"......
Mine does that often, and 90% of the time it is a loose ignition. Wiggle the key while intializing.
or ****-eyed plug into the aldl.
SHAGGY
SHAGGY
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
My auto-xray links great in my Cavalier and Bravada, but it gets challanging with my Camaro. I think it relates to the ALDL plug!
