Parts for Sale 2006 Keep it Third Gen related please!
Brand new vortec heads,vortec airgap,eagle h beam rods.
Old 04-15-2005, 11:42 AM
MarkB's Avatar
Car: 1982 T/A -1986 Z28
Engine: 383 -305
Transmission: T56-700r
as the title says....im just cleaning out stuff im not using.
BRAND new never used/installed GMPP vortec heads. $450
BRAND new never used/installed performance plus polished air gap intake for vortec heads $135
brand new eagle H beam rods 5.7 length,all still sealed in factory plastic $285
i purchased the heads for 500,intake for 180,and rods for 330,not trying to make money,just get rid of **** im not gonna use.
Attached Thumbnails Brand new vortec heads,vortec airgap,eagle h beam rods.-112484491wjabto_ph.jpg
MarkB is offline
Old 04-15-2005, 11:43 AM
MarkB's Avatar
Engine: 383 -305
g
Attached Thumbnails Brand new vortec heads,vortec airgap,eagle h beam rods.-112484540pvjdqy_ph.jpg
MarkB is offline
Old 04-15-2005, 11:44 AM
MarkB's Avatar
Engine: 383 -305
Attached Thumbnails Brand new vortec heads,vortec airgap,eagle h beam rods.-112484431mhefut_ph.jpg
MarkB is offline
Old 04-15-2005, 11:45 AM
MarkB's Avatar
Engine: 383 -305
Attached Thumbnails Brand new vortec heads,vortec airgap,eagle h beam rods.-114638626yarxcz_ph.jpg
MarkB is offline
Old 04-15-2005, 12:05 PM
82whiteZ28's Avatar
Car: 1982 Camaro z28
Engine: 5.3
Transmission: TKX
Axle/Gears: 10 BOLT
how much for the whole package?
82whiteZ28 is offline
Old 04-15-2005, 01:03 PM
MarkB's Avatar
Engine: 383 -305
750
MarkB is offline
Old 04-15-2005, 02:54 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
would you do $450 shipped for vortec heads? shipping to 44883
jstoltz is offline
Old 04-15-2005, 03:07 PM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Are the rods set up for press fit pins or floating????
Let me know...
nwokenwood@yahoo.com
Kenwood is offline
Old 04-15-2005, 06:44 PM
dang's Avatar
Car: 85 trans am
Engine: lg4
Transmission: t5
Axle/Gears: 3.27 9 bolt
i want the heads and intake ya punk biatch
dang is offline
Old 04-15-2005, 06:56 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
LOL what kind of lift can those heads take?
7plagues is offline
Old 04-15-2005, 09:37 PM
84-350berlineta's Avatar
Car: 84' Camaro Berlinetta
Engine: 383
What type of steel are the rods? Do you have the part number?
84-350berlineta is offline
Old 04-15-2005, 10:34 PM
MarkB's Avatar
Engine: 383 -305
the rods can be either press fit,or full float,depends on the pistons you use. but my intentions and pistons purchased were full floats,i have the pistons as well,just forgot to list them.
as far as what material the rods are,i have no clue...4340 comes to mind,but dont qoute me.
look up the specs on eagles website,i was told they are good to 1000 hp
Attached Thumbnails Brand new vortec heads,vortec airgap,eagle h beam rods.-114638680xdtmns_ph.jpg
MarkB is offline
Old 04-15-2005, 10:37 PM
MarkB's Avatar
Engine: 383 -305
.475 is max,unless you upgrade to beehives,or have the heads modified {which i intended doing but i purchase AFR210S instead.
also here is a pic of the pistons,brand new in box,only opened for pictures.
these are setup for a 383 with 5.7 rods full float,pins and spiro locks are still sealed in the box
i beelive if i rememebr correctly they are 10.2 to 1 with a 2 valve relief flattop...that CR is based on 64 cc heads,also they have the skirt coating option.
Attached Thumbnails Brand new vortec heads,vortec airgap,eagle h beam rods.-114638753vfzvtz_ph.jpg
MarkB is offline
Old 04-16-2005, 11:58 AM
89BlueRSCamaro's Avatar
Car: 1989 IROC-Z
Engine: 350-5.7L
Transmission: 700R
so the intake manifold....it is for vortec heads....since i dont know much bout parts...with that manifold, would i be able to use a TPI set up...i mean can i attach to it a TPI plenum and runners.....
89BlueRSCamaro is offline
Old 04-16-2005, 03:07 PM
MarkB's Avatar
Engine: 383 -305
no,the intake manifold is setup for a carburated application
MarkB is offline
Old 04-16-2005, 03:29 PM
Engine: 383
Do you have a part number on the pistons? Forged or hyper- eutetic?
Old 04-16-2005, 04:16 PM
MarkB's Avatar
Engine: 383 -305
they are hyperutectics,and i wil lget the part number for you,i do not know it off hand.
MarkB is offline
Old 04-17-2005, 06:53 PM
MarkB's Avatar
Engine: 383 -305
ttt
rods pistons are pending....heads are up for grabs
MarkB is offline
Old 04-17-2005, 11:52 PM
Car: 1989 IROC-Z
Engine: 350-5.7L
Transmission: 700R
how much you asking for them....
Old 04-17-2005, 11:54 PM
jstoltz's Avatar
are these drilled for standard intake pattern and perimeter covers also? Thanks John
jstoltz is offline
Old 04-18-2005, 12:34 AM
7plagues's Avatar
would you do 450shipped? on the heads
7plagues is offline
Old 04-18-2005, 02:16 AM
MarkB's Avatar
Engine: 383 -305
yeah i would do 450 shipped on the heads.
MarkB is offline
Old 04-18-2005, 08:02 PM
MarkB's Avatar
Engine: 383 -305
ttt
MarkB is offline
Old 04-19-2005, 08:10 AM
86LG4T56's Avatar
Car: 1986 Firebird
Engine: LG4 305
I'd give you $375 for the heads plus shipping...
86LG4T56 is offline
Old 04-19-2005, 03:15 PM
MarkB's Avatar
Engine: 383 -305
LOL,sorry but no.
update,everythings sold. {asuming all the money shows up from the buyers}
MarkB is offline
Old 04-19-2005, 08:56 PM
MarkB's Avatar
Engine: 383 -305
update....buyer on the intake fell through...so its up for grabs.
FYi...its a polished perf RPM airgap knockoff,power products i beleive is the brand,this is for vortec heads.4150 style carb mounting plate for holleys,or edelbrocks.
MarkB is offline
84z96L31vortec
08-20-2017 12:16 AM
bamaboy0323
09-03-2015 06:07 AM
theurge
08-21-2015 12:46 PM
L98GTA87
08-11-2015 06:55 PM
84z96L31vortec
08-10-2015 08:27 PM
Quick Reply: Brand new vortec heads,vortec airgap,eagle h beam rods.
