Deleted the AC, pictures in here
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
my engine compartment was way to cluttered....so..I decided to buy a standard heater box, the ac delete pulley and a pulley to get rid of my smog pump. Turned out pretty nice....but now...I'm dealing with those bright yellow ugly plug wires...
Engine: 5.7
also thinking about ditching the vette covers...and getting a nice set of black valve covers...or refinishing mine.
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
looks clean man! i personally like the vette covers, the black valve covers would look pretty good too, im one for a black and silver/polished engine bay
Car: '02 Z06
That's probably the most tasteful looking TPI engine bay I've seen to date. I personally like the vette covers, the red makes a nice subtle contrast. Maybe get "Camaro" lettering, but I'd deffinitely keep that bit of red in there.
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
I love the ac delete box....where can you get one? Ive never had the ac hooked up in my car since Ive owned it, and never plan to (thats what t-tops are for)....how hard is the install....seems pretty straightforward
....I love the vette covers too....as odd as the pairing is (vetter covers on a maro) it's always been cool to me
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Keep the vette covers. As for the yellow wires go with either MSD 8.5mm red or black and route them under the headers/manifolds. That's how I went with mine and it really helped clear up the clutter.
Engine: 5.7
did some more clean up work with the wires and harness's....not sure that I even need black plug wires now
Car: 1987 Z-28
Axle/Gears: 10 Bolt/3.23 peg leg :(
both of you guys have BEAUTIFUL engine bays, wish mine was just like that. One of my winter projects is to get my hands on an A/C Delete box and install that puppy, how hard is it? Like stated before it seems pretty straight forward, but are there any tips/tricks that go along with it?
Engine: 5.7
I got the heater box for $75 bucks from IrocZDave...he has his own website. I had to change the resister (only 2 bolts, very easy) and hood up the ground and power to the blower motor, that's all. Over all a pretty easy mod....and it cleaned up the engine bay very well. I bought the AC delete pulley thought gmpartsdirect...and paid about 50 bucks for that. I also bought the Smog Pump Delete Pulley and got rid of all of that too.
Car: 1986 Camaro z28
Engine: 305 tpi/light mods
Transmission: 700r4/ B&M mega shifter
Yeh i like the vette covers too they're almost as cool as seeing vette callipers through the rims of a camaro.
Car: '85 Z28
thanks for the info
Engine: 5.7
Originally posted by 85_ZED28
does it work with the stock ac interior controls?
thanks for the info
thanks for the info
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Dialed in. I like the extra cooling you have. Thats a good idea. That will keep the back cylinders a little cooler.
when you guys buy the non a/c box do you jut buy the outer one ? the one under the hood only ?
dont have to swap the interior box out ??
are the interior boxes all the same between a/c and non a/c ??
they arent on other makes and models, such as full size cars, and trucks,
the inside boxes differ alot between a/c and non a/c on other makes and models i know
f bodies must be oddball and share all the same inner box
hmm..
hmm..
Car: '88 IROC-Z medium orange metallic
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
hmm..
hmm..
I just did the engine side box since it is the easiest to get, but I do have the vent block off plates and the non-ac controls in the garage.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
looks tight, but i like how the yellow plugwires mix up the silver and black a bit.
You can hide them, but you know they're still there...haha.
once again, SWEET camaro!
Brandon
Brandon
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
this is just the thread I was looking for! Im doing the exact same thing you are! Im in the process of deleting my AC and right now im bidding on a AC delete heater box and got my 1LE ac delete pulleys coming in from gm parts direct, for a while I have been wondering and being concerned if the air controls work except for the AC obviously, but now I know thanks to you! How long did it take you to do all of it? 1 day?
Hotrodboba400
12-10-2019 07:07 PM
tonys91rs
10-10-2015 03:31 PM
