Who makes the best TPI lower intake?
Car: 1987 Formula 350
Engine: TPI 350
The choices are:
1. ACCEL
2. TPIS (bigmouth)
3. Edelbrock
4. Scoggs/Dicky
1. ACCEL
2. TPIS (bigmouth)
3. Edelbrock
4. Scoggs/Dicky
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Accel.
Edelbrock makes TPIS's intake, but TPIS port matches there's. However, the Edelbrock base has been known to strip, warp and crack for several members. I would only by the edelbrock base if it was $150 new, $100 used.
The Scoggs intake hasn't had any problems that I know of, but it only fits Vortec heads....
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Ive heard alot of good about the super ram base (accel)
Accel is mighty proud of thier base nowadays, last time I looked at jegs and summit the base was over $500...
I got lucky in a group buy a few years ago, think I paid about 300 or so for the one on my car...
Just picked up a Accel base and SR intake, and notice they now cast the Vette EGR in them...could be the difference in price, I dunno.
Thing is, I've heard horror stories about the Edelbrock (search, and you'll see about fuel rail bosses, ect) but never heard a negative about the Accel base.
SR installs another story, but I have a set of heli-coils to cure the install issues everyone gripes about.
Oh well, just rambling on...
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
My old Accel base (circa 1995) had the Vette EGR cast in it.
You're right though, Accel is awfully proud of that base. I paid 380ish for mine 10 years ago and I still thought that was expensive. Especially considering back then you can get an upper AND lower intake for a 5.0 Mustang for a little over 500 bucks.
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Axle/Gears: 3.23 Dana 44
Definitely Accel. Don't get Edelbrock whatever you do; they have the worst quality control ever makes you wander if they even have quality control or if everything they makes gets shipped out without even being checked. Everything I have bought from Edelbrock has been out of tolerance or just not right. Do a search and you will find many people have the same problem.
Another vote for the Accel. I'm running it along with all of my SLP parts.
I've always had problem with my EGR code going off since I installed it though. I'm thinking it's my screw up somewhere or the used intake I got was clogged, which it didn't seem to be. I installed a new EGR at the same time too.
Car: 1989 Iroc-Z
Originally posted by KamikazeIroccy
I like it, looks stock but extremely sexy, and with a little porting it's good to 6500 rpm
personaly I was interested in getting the Edelbrock set-up myself. I like it, looks stock but extremely sexy, and with a little porting it's good to 6500 rpm
Engine: TPI 350
wha about the ones ins SuperRod? I think you should scroll up and check it out.
In the superod shootout that you're refering to the Edelbrock system made(IMO) peak power at 5200-5300rpm not 6500 rpm. They did say it extended power to 6000 rpm but if you look at the graph it dips and goes back up which is not really buidling power.--Thats just how I see it. --With that said, that is better than stock peak power.
Do you have the combination they used, because I'm really shocked it made peak power above 5 grand! I mean, hell, if it made peak power at 5300 RPM, that's nearly an LS1's power range, with their peaks occuring in the 5400-5600 RPM area.
I'd really have to see a chart to look at that. Do you have a link to that article or scans, or anything?
Engine: all 225+ RWHP
Transmission: all OD
I would bet the First setup would still be doing good there.
More than likely so would my prototype TPI setup I purchased :-)
The runners and base on both of these have some real meat unlike the stock and the aftermarket bases.
Stock base can be ported to hell, and I'm not sure why more people dont do it though.
But if pure rpm for power is the goal, the TPI aint the ticket to go there any way u slice it.
later
Jeremy
later
Jeremy
Engine: TPI 350
There you go, my homie got me@KMA.com
Fmandan - that article was pretty badly flawed. I don't see anyone running a 236/242, .520/.540 cam in a street 383 that has to pass emissions. The Trickflow heads were the 215cc heads, which isn't exactly common either.
I still maintain that in a regular LTR street machine (215/225 MAX, 200CC intake runner MAX) that the edelbrock setup would die off long before that. On the upside - the low end would probably be significantly more tolerable. Hell, even the stock TPI made 410 HP, and the edelbrock setup only gained 1 ft lb. That test was all messed up, and it was definately a ploy to make the HSR/MiniRam look good. The engine was just not suited for a LTR form of induction.
Plugs...go under the car.block it well...hate to see you tugging on a plug while the car is up and have it fall on you
Edelbrock is soooo far from the stock look...but the runners do look cool.
It's tough getting the middle "Transitional" area of the runner in the base smooth, while taking any real meat away. I had to employ my kung fu ninja "Pinky and Thumb" grip the last time I tried...
Then went through it with a bottlebrush hone I got from a dairy supply store...IIRC, it was a 2inch hone for milktank lines...the shaft on the hone was like a wrapped coil of wires, made it pretty flexible and easy to get it pretty even.
After all th work I didi and few years later I went with an Accel base...had I known the differences, I'd have popped for the 3bills much earlier
I had a heck of a time with mine. No matter what I did, I just couldn't get the middle area smooth enough for my tastes. I say congrats to those that can do a good job on them, I wish I knew how.
Originally posted by 1989GTATransAm
Attached is the dyno results from my TPI 350. Cam is a ZZ9 clone with 212 degrees on the intake.
What did you do to the baseplate? Did you just knife edge that, or did you cut some back there as well?
Who did you have do the Extrude Honing? The only place I saw online to do it wanted in the range of $350 for a base, $550 for the base and runners.
I had Extrude Hone do it here in Southern California. Cost me $375. It did turn out real nice with 1.70" ports on the runner side on the intake manifold.
I did not want the intake manifold to flow less than the heads and be a restriction. From other tests I have read the manifold should flow around 275cfm. The heads are around 255cfm.
From the mods I did I know the runners and the plenum are not a restriction. Hehehehe.
Wow - if you bought the plate new you have about $700 tied up just in the base plate. That's commitment to an idea, now slap a bigger cam in there and see what she really has
i got an Accel superram base.... and i must say i like it but it needs some work.
the base has alot of room for porting and should be done. especially if your trying to get as much rpm and power out of a LTR setup. i'm currently doing mine and am satisfied with the the amount of room i have to open up. i just need to get to the middle transition part of the base to really gain the flow i'm lookin for
Actually I do not have quite that much tied up in the manifold. I bought it around 1991 and did not pay nearly what they sell for today. As to the cam you are not the first one to suggest a larger cam would really benefit my engine and the horsepower output. I'm "thinking" about it. Hehehehe. Might be what is required to get me into the lower 12's.
The Accel base is pretty straight forward, you can look though one port to the other side, and in stock form, see about 60-70% of the other port opening....don't see why it'd be difficult to get to the 'transition" srea...since there really isn't one...aka stock base...been so long snce I had it up in the air, but pretty sure I couldn't see daylight thoufg it...totally night and day difference to the Acccel base's I have...
I guess I could go dig in the pile for a stock base for comparison, might do it tomorrow, just to satisfy my memory
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
... The Trickflow heads were the 215cc heads, which isn't exactly common either...
Car: Tree Huggers
Engine: Do Not
I had a big mouth a few times now and can say I've been happy with each one. My preference is also to use the AS&M runners.
Originally posted by Red Devil
Where exactly did you glean this info from?
170-200cc heads are common, 215cc heads are not. If you have a problem with that, get offline, and go to a track and start flexing those exellent communication skills and talk to people running strip/street small blocks.
Edit in: Okay, I'm sorry, I just pulled it out of my @ss just to sound important, and liked hearing myself talk. That's it buddy, you got me.
Originally posted by Orr89RocZ
i wouldnt mind running trickflow 215 heads on a 415 with a superram. i think that would be nice.
However, for every one of those, there's 3,000 355's running much more suitable heads (no monster ports).
Car: Tree Huggers
Engine: Do Not
The track.
The track.
Where did you get the 215 runner size from?!?
They didn't say R series heads, they just listed them as 23 degree TFS heads. I know, I'm the one who contacted them about the heads.
Unless the 23 degree heads are noted as R series heads, the runner size is 195cc... unless TFS doesn't know their own product too well. Take the attitude elsewhere.
[B]A little dim, or just hung over? I'll make it a little clearere for you...
I emailed the mag.
Car: 1989 PONTIAC FORMULA - 1992 PONTIAC TRANS AM
Engine: BOTH 5.7L 350
Transmission: BOTH 700-R4
Re: Who makes the best TPI lower intake?
I WAS TOLD THAT THE EDELBROCK AND TPIS MANIFOLDS ARE BOTH MADE BY EDELBROCK!
Car: Tree Huggers
Engine: Do Not
Your own personal crusade against lawyers huh? The mag made no mention of 215cc runners to me, they were rather explicit that they were regular TFS 23 degree heads. I'll have to email them again. That would be a tad shady.
Procharged, they are. TPIS just port matches them and cleans them up a little.
Musta installed it after a few cold ones and forgot...
So, both the intake I recently got as well as the one I've had for years, both are the same.
1992 Trans Am
05-10-2023 07:19 PM
1992rs/ss
05-19-2020 07:02 PM
9192camaro
16
02-03-2019 12:21 AM
NBrehm
08-25-2015 11:49 PM
