I've searched but not found the C207 pin out for a 91-92 speed density camaro
Can some one please help me find the pinout for the C207 of a 91-92 camaro?
if you had it for a vette, that would be great as well.
i also need it for an 87 LG4, but i've found that already.
thanks
thanks
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
A...Air sw.
B..Fuel Inj.
C..SES light
D...Fuel pump ?
E...Diag.
F..Ign. ECM
G...Fuel INJ.
H...TCC control.
J...Serial Data
K...Speedo
L...VATS
M...Batt.
N...P/N sw.
P...Cruise control
R...Crank sig.
Not positive on the fuel pump
B..Fuel Inj.
C..SES light
D...Fuel pump ?
E...Diag.
F..Ign. ECM
G...Fuel INJ.
H...TCC control.
J...Serial Data
K...Speedo
L...VATS
M...Batt.
N...P/N sw.
P...Cruise control
R...Crank sig.
