code 12? did i do this right?
Old 09-06-2004, 07:41 PM
cyipher's Avatar
Car: 1984 Pontiac Trans Am
Engine: 305 SBC
Transmission: Automatic
what is the description of a code 12 and how do i fix it? I tried using the search and it wot let me search "12" because of the length.
Old 09-06-2004, 07:42 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Code 12 is normal, don't worry. I believe that code lets you know your in diagnostic mode.
Old 09-06-2004, 08:28 PM
cyipher's Avatar
Engine: 305 SBC
ok found the problem.... its code 32 the car is a 84' Fbird with a cc carb
Old 09-06-2004, 08:54 PM
cyipher's Avatar
Engine: 305 SBC
ok i did find the problem.....http://www.asashop.org/autoinc/feb2004/techtotech.cfm all the way at the bottom.
Old 09-06-2004, 09:39 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Code 32 can also be associated with the ever so elusive EGR.
Old 09-06-2004, 10:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You are quite correct in that Stekman, however cyipher is correct in what he has found even though it does say 84 camaro. This is what the code 32 is for his car. "Baro Sensor Voltage Low". Maybe this will help him.
Old 09-06-2004, 10:27 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
part 2.
89-IROCZ-5.0TPI
02-22-2022 09:26 PM
Falcon50
08-22-2020 03:26 PM
racereese
10-03-2015 03:46 PM
Luigytico09
10-01-2015 08:46 AM
dusterbd
09-29-2015 08:40 AM
Quick Reply: code 12? did i do this right?
