Good 305 lg4 cam?
Old 06-06-2004, 01:43 AM
Naphead's Avatar
Good 305 lg4 cam?
84 TA, 305 4 barrel, I put a performer intake (2101), 650 holley, 50,000 coil, flowmaster exaust and everything else is stock . Now Im looking for a better cam, i'm hoping for 50 horses more w/ a cam swap.
What kinda specs should I be lookin for? and what kinda lifters?
Thanks, C-ya
Old 06-06-2004, 02:24 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
50 horses with just a cam, no mods to the heads...no comment.
do a search. If you did, you would have found these:
https://www.thirdgen.org/techbb2/sho...hlight=LG4+cam
The list goes on and on and on....
Old 06-06-2004, 02:29 AM
Naphead's Avatar
LoL I ment w/ all those mods I already did PLUS a cam to get 50 hp more.
C-ya
Old 06-06-2004, 02:35 AM
Naphead's Avatar
oh and I dont need to worry about emissions either, we dont have it here.
Old 06-06-2004, 02:38 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Without any further info, i cant give a very educated guess, so ill just toss out an idea. Run a solid roller cam with mid .700's lift and 290+° duration @ .050" on a 106° lobe seperation angle.
Give me info about your transmission, rear gears, desired RPM range, budget, any plans for heads, and every other aspect pertaining to your engine and i can give a better suggestion.
The closest thing to an honest suggestion i can give now, other than DO A SEARCH *cough cough* is save up for a 350.
Old 06-06-2004, 02:44 AM
Naphead's Avatar
LoL yea, the numbers 350 crossed my mind plenty of times, but i'm trying to keep my mods all bolt on so I can swap them later if needed.
The car got 700r4 (b&m shift kit) and a 2.73 rear end (blah)
Thanks for the help
C-ya
Old 06-06-2004, 02:46 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Xe262h and upgrade the valve springs.
Old 06-06-2004, 07:41 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
To get the best results with a new cam you will need to port the heads, upgrade your exhaust ect... Its all about matching the total combination. I was using a Crane 274H cam in my old 305 and running a 13.4 with it. Heres a link to my 305 mods.
http://www.geocities.com/jbenge/about_car.html
Old 06-06-2004, 12:13 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
You have to completely junk the stock exhaust and start new with headers and a good 3" exhaust system. If you don't swapping a cam will gain 0 hp and will hurt performance. The bottle neck is not the cam right now but the exhaust.
But i would suggest the comp XE262 if you plan on upgrading the exhaust and then maybe the heads.
Old 06-06-2004, 01:00 PM
Ray87Z's Avatar
Car: 94 Z28
Axle/Gears: 3.23s
The XE262 is a bit much for a automatic equiped mild 305. I'd go with the cheap generic 204/214 dur @.050, .420/.442 lift cam Summit and others sell for under $100. It will gain power even with the stock crap exhaust, but to really take advantage of it I'd add at least a cheap set of headers at the same time or as soon as possible. With the other mods you have with the cam in addition to a decent set of headers you'll be making significantly more power than stock... 50 hp gained might be a bit conservative in the end, the stock intake, exhaust, and cam are just that bad...
84z96L31vortec
08-20-2017 12:16 AM
Reborn756
09-04-2015 03:42 AM
camaro71633
09-01-2015 10:24 AM
84z96L31vortec
08-10-2015 08:27 PM
drathaar907
08-06-2015 04:20 PM
Quick Reply: Good 305 lg4 cam?
