CCC carb hack now available
Today I uploaded the $40 mask to http://moates.net/fileman/index.php
This is for 1228079 and is named 8079.src. This mask was used with most if not all 87 and 88 CCC carbs.
Enjoy
John
Enjoy
John
Car: An Ol Buick
Engine: Vsick
Re: CCC carb hack now available
What file name is it under, and in what category?.
Car: An Ol Buick
Engine: Vsick
Source code and ecu hacks. It's right above 8746.dsm.
John
John
Got it thanks.
Car: 84 Z28
Axle/Gears: 9-bolt, 3.27
Wow! This is wicked awesome! Different ECM than I have, but would be easy to make one work! Is the original bin out there, too? I would be willing to do SOME work on a ECU file....... In fact, I'm starting one.......
Actually I have good starts on the 84, 85, and 86 ECM's also. The Knock stategy changed for later years and the early stuff is still a mystery. One of these days I'll destroy an ECM to find out what it really is.
I've got the 88 SS bin. I also have the 85 SS and a couple of LG4's. Kinda be cool if we could get people to pull and post them. Maybe we can get a ZZ4 bin posted. Posted the 88 bin under stock bins. It is called 88ss_l69. The 85 SS bin is called 85ssCPY.
John
John
Car: '87 Formula
I'd be willing to contribute my '87 LG4 bin file, if I can find time to get it read from someone. I'm new to this yet, but I'd like to get into it now that theres actually a starting point to go from (a.k.a. it seems more possible to me now) for these CC Qjet systems.
Car: '87 Formula
32V_DOHC, not to steal any secrets or anything, but how do you people come up with this stuff?? I mean, seriously, where'd you get it from or how did you figure it out?? I'm really curious.
Car: 84 Z28
I have a few items coming our right in my ecu file that I'm working on, but some things look weird. It looks like it's pulling all the timing out as the MAP Kpa and rpms both go up. I thought it was just how I had the ECU file, but the values in the hac reflect the same. Anyone know anything about this? If that's how it's working, it would explain how my carbed car is running!
Car: check
Engine: check
Transmission: check
At 2,400 RPM & 100 KPa 12-13 degrees is about right. This is with 87 octane fuel.
RBob.
Car: 84 Z28
Originally posted by RBob
These engines can't use much timing. I converted an '85 LG4 over to TBI and the timing is minimal.
RBob.
RBob.
I need to do some more work and start trying stuff!
Engine: all 225+ RWHP
Transmission: all OD
Any word on a version for Olds engines?(or is ther mask the same)
We have bnever been able to get anythign worth a hoot :-) lol
I know the ecm's and pintouts were slightly different?
Any info please let me know?
later
Jeremy
later
Jeremy
Car: 84 Z28
later
Jeremy
later
Jeremy
Originally posted by anesthes
Is the '83 carb ecm the same?
-- Joe
-- Joe
later
Jeremy
later
Jeremy
John
Car: check
Engine: check
Transmission: check
CPK
I've uploaded (moates) the CPK bin & txt file (stock bins dir). This bin is from an '85 LG4 w/a CCC Quadrajet. The beginning portion of the bin is similar to the '8079 stuff. Didn't look much further then that.
If it wasn't for this thread I wouldn't even had read it
RBob.
RBob.
Car: '87 Formula
32V_DOHC,
I have a quick question. Not to sound dumb here (because I'm still quite new to this, but I have done some assembly language with Intel chipsets), what is next? I could not get the source code to compile (didnt expect it to) and I havent done any compiling in a while, and I dont even know where to start with the 7xxx errors, because it has been a while since I've even looked at AL. So, does this source file need assembled at all, or can it just be read through to make the ECU file, and then just load the .bin file (assuming its the correct .bin file for the ECU definitions) into TunerPro or whatever your using? I've already started on the ECU file but I'm not REAL sure I'm doing the right thing yet. I've only gotten to about address location 0007 so far, just to see if I'm doing it correctly. Seems to read the values in just fine, so far. Is this the next step? Or does something else need done or 'checked over' first? (aka, the source file?).
Also, how do I go abouts finding the checksum size and address?
I'd assume the checksum start address and end address are just the start and end of the file address (what you have labeled in the source file as 'file start' and 'file end' or 'disassembly start' and 'disassembly end' addresses?
Ok, maybe that wasnt such a quick question, sorry. I've already learned a bit just from reading the source file, and things are becoming more clear here, so bear with me if you can!
Thanks for your time.
-Ben
-Ben
Car: '87 Formula
Oh, I used Hex workshop to read the binary file, and did a checksum calculation, and it gives it in -8, -16, -32, -64. Do I use one of these values, or one of the other (CRC-16, etc)?
Will I come across the checksum address in the source somewhere? Or is that defined elsewhere?
The posted hack is far from ready to assemble. It wasnot done with that in mind. If one was to go to source code with this the board would need to be made romless and the calibration part moved to $C000 or something like that. If I were going to do that I would start with a code seeking disassembler that allowed for commenting from the control file and with scripts.
As far as a checksum there is not one. Just acheck byte to identify that that PROM goes with that ECM. Since the CCC carb proms were BPROMs checksum protection was not needed. If one was to source code this mask for romless a checksum routine should be added to insure the bits don't change.
HTH
John
HTH
John
Car: 84 Z28
HTH
John
HTH
John
Sorry, but I'm not all that technical at this level.....
Car: 81 Turbo Trans Am
Engine: 301 T
Transmission: 200-4R
32VDOHC,
Was the 8079 ECM architected like the 7747? By this I mean were *all* of the contents in the 8079.src file located on the removable chip? Or, did you have to come up with a way to download the portions of code located in some of the "permanently soldered" chips within the ECM? Rbob, was the '85 CCC stuff this way, too? My impression is that the 7747 has software located within the bowels of the non-removable chips that make source code changes difficult without some intensive engineering changes to the hardware.
It would seem that in the event all the source code was located on the removable chip, it would be relatively easy to implement source code changes for these applications. (Not withstanding the effort to come up with an appropriate understanding of the software! ) The biggest difference would be programming an 81S181 rather than a 2732/27128/27256. Given this condition, I don't think we'd have to move any of the calibrations around within the memory itself?
Let me know if this is just wishful thinking! Thanks!!
Ok, so what is a BPROM? Is it a program once device? To burn chips for it, what chip would it take? If this is too much trouble, I'll just use a timing only setup with a 730 (since I have one sitting here). Also, to edit in tunerpro, what would you tell it for the checksum address?
For the checksum I started by using winbin and having it ignore the checksum. My latest thought to try is telling tunerpro the checksum is the promid. Run the checksum on all but the last two bytes and let it fill in those. They are never referenced so it will be cool.
John
Originally posted by 1981TTA
32VDOHC,
32VDOHC,
If you wanted to do source code the easiest way is to convert the board to romless and use a 27128/27256/27512. Once you have source coded the code and cal you could easily move the cal to have all the code and cal fit within a 27128 with plenty of room to spare.
HTH
John
Car: 84 Z28
The code part is on the RAM/ROM/IO chips. They must be removed from the board to be read or you would need a board that would provide Eprom reader type capabiltiy from the edge card. I don't know of anyone who has done the latter.
HTH
John
HTH
John
If only I could use an Autoprom, or Prominator in it......
I'm still debating whether I really want to buy a chip burner to mess with this, especially since when I do start into the EFI, I plan to use a Prominator, or Autoprom.
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
ZZ4 bins uploaded
The GM ZZ4 Conversion Kit bins have been uploaded to the stock binaries section of Moates' site.
Filenames start with ZZ4, so scroll all the way to the bottom.
Credit goes to John (32V DOHC) for reading them -- I had some difficulty reading the N82S181 chips, so I ended up mailing them to him.
Car: Pontiac Firebird ´87
Engine: L69 305
as this is linked in the sticky and the link does not exist any longer, here the updated direct link to the new place of the files:
http://gearhead-efi.com/gearhead-efi/bin/
2012sergen11
10-13-2015 07:38 PM
Damon
09-26-2015 04:29 PM
