code 13
Code 13
i just got a code 13 on my 91 RS... that means that the oxygen sensor is running lean correct? how do i fix that on a LO5 setup with the stock tbi and stock exhaust manifolds
you need to follow a diagnostic chart for that code. Other than that you're just throwing money at it and may not fix the problem. make sure the wiring looks good and the sensor is not damaged or covered in anything like a melted plastic bag, tar, etc. Any contamination of the sensor can damage it. Kyle
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Code 13 means you are lean at normal operating tmeps. What do you have your fuel pressure set at? Are you running the stock injectors and fuel pump? It sounds like you need to get into a custom prom and upgrade your fuel system.
everything is fine with that sensor, no debris or anything... i have a custom prom from TBIchips.com and im running the 55lb/hr injectors used on stock LO5 caprice cars and im using the stock fuel pump
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Chiltons manual has those in it for both the tbi as well as tpi systems. Think theyre reprints from the factory service manual.
Car: 88 Camaro SC
Engine: SFI'd 350
Where is your O2 located? A set of shortie headers or mans. shouldnt cause any problems with the O2, even if the motor runs cold. The exaust is going to be pretty damn hot even if the motor has a low temp t-stat. Best bet is to check the circuit between the ecm and the O2 to make sure its still intact and then buy another O2. Sounds like your present one is dead.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
To GTA324,
Those are from the GM service manual and I have it for the L98 as well, do you need it. I also have a chiltons manual and these schematics and troubleshooting charts are not shown in the copy I have. If they are in it, It must be a more updated copy than the one I have. They also are not in the haynes manual I have.
