Pulled AIR pump + Underdrive pulleys
Car: 92 Camaro RS
Transmission: T5 manual
I pulled the AIR pump over the holiday. I rerouted the belt like it’s shown in the tech article, but since I also installed March under-drive pulleys I was able to continue to use the standard size serpentine belt.
What do most people do with the two wiring connectors that hooked into the AIR system?
Car: 87 Iroc Z28
Engine: 355 TPI
I did pretty much the same thing, only my car was origonaly a vbelt setup. Now with the march underdrives I have 1 serp belt going around the crank pully, water pump pulley, and the alt. Then there is a vbelt that goes off the crank pully up to the powersteering. It was a pita to find the right belt size cause it was all different from what march said being that I took off the AIR pump.
As far as the wires I completely removed them and everything else for the AIR setup when I had the motor out.
Kevin
Kevin
evilstuie
01-09-2020 08:29 PM
Navy8125
08-22-2015 07:13 PM
mcquigg
08-13-2015 02:26 PM
